993 Forum 1995-1998
Rim painting rig
Old 07-24-2016, 05:01 PM
Ron
Ron's Avatar
Default Rim painting rig
Photo shows my rim painting rig with rim mounted. Wheel on rig has been primed and has color coat applied.
still needs clear coats applied.
Paint inside of hub first, then when dry insert fixtures into hub, tighten fixtures place on jackstands. move by turning rod.
Old 07-24-2016, 06:10 PM
pp000830
pp000830's Avatar
Received 1,441 Likes on 1,015 Posts
outstanding!
Did you use a two part urethane finish?
Old 07-24-2016, 08:29 PM
P-daddy
P-daddy's Avatar
Nice rig Ron. What's the BAF for?
Old 07-24-2016, 10:34 PM
XavierLaFlamme
XavierLaFlamme's Avatar
I am impressed. When I redid my wheels it was a lo-fi approach compared to your rig!
--Michael
Old 07-24-2016, 10:47 PM
bcameron59
bcameron59's Avatar
What's the insert between the wheel center and the rod? AKA "fixtures".
Can you post some close up pix?
Old 07-24-2016, 10:56 PM
bobbyp
bobbyp's Avatar
Parts list please
Old 07-25-2016, 03:03 AM
Pichu
Pichu's Avatar
Originally Posted by bobbyp
Parts list please
Group buy!!
Old 07-25-2016, 11:05 AM
Ron
Ron's Avatar
Will try to answer questions asked.
Used devilries SRI spot gun with 1.0 fluid tip.
2 coats of all products were applied.
all coating are Sherwin Williams products.
primer is 2 part urethane, that is primer and hardener
basecoat is Dimensions high hiding arctic silver metallic : reducer used was based on ambient temp.
2 coats of ultimate clearcoat
not sure what BAF stands for
metal rod that goes thru center of hub spacer fixture or whatever it is held in place by a collar bushing that is tighten with setscrews.
I did not make the spacers. I took one of each size rim t my machinist and explained to him what I wanted. He took all measurements and made them out of wood. I had asked for aluminum abut here said wood will be fine. He was right.
Old 07-25-2016, 11:23 AM
JimPA
JimPA's Avatar
Big Ass Fan, I suspect.
I tried a lower tech approach, using a purpose-built wood frame and rattle cans. Results were, perhaps predictably, not as attractive as yours.
Old 07-25-2016, 12:10 PM
bcameron59
bcameron59's Avatar
Perfect, wood is easy to lathe and less risk of scratching the painted inside of hub compared to metal.
My nb techno wheels need a respray, I will shamelessly plagiarize your method when I do that.
Thx for posting! You wheels are looking reat btw
Old 07-25-2016, 01:00 PM
JDHertz11
JDHertz11's Avatar
Very cool idea. I saw this setup on Instagram last week and thought it looked really nice as well.
Old 07-25-2016, 03:03 PM
Ron
Ron's Avatar
painting in temps in the 90s and high humid fans are very helpful. they can also direct overspray and help keep bugs away.
Quick Reply: Rim painting rig
