993 Forum 1995-1998
Paddle Shifters in a Tip Questions, Any Info?
Old 07-24-2016, 04:50 PM
AC/911's
AC/911's's Avatar
Default Paddle Shifters in a Tip Questions, Any Info?
Just picked up a Nice 97 Tip S, I remember seeing a Car in the For Sale section with Paddles put in, These Guys in the link below say they can do it For $1000?
Any Info or Links to other Member doing this would be Much appreciated, Thanks
http://www.ebay.com/itm/301731278840?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 07-24-2016, 06:59 PM
shadow993
shadow993's Avatar
A few guys have accomplished this on 997's using Mercedes paddles.
Old 07-24-2016, 07:25 PM
Spokes
Spokes's Avatar
Default Tip paddles
I have seen a few use this product...
http://www.evasivemotorsports.com/mm...=WB-PADDLE-NEO
Old 07-24-2016, 07:47 PM
600RR
600RR's Avatar
Rennlist sponsor has them and they are very, very nice. Located at Club Autosport in San Jose - great shop - see post #4 https://rennlist.com/forums/993-foru...-san-jose.html:
RRS LLC
Phone number: 650-714-4340
521 Charlot Ave Suite 209
San Jose, CA 95131
Old 07-24-2016, 08:07 PM
David993S
David993S's Avatar
I guess these would be a "contemporary" addition, however I've never seen the benefit. One can already shift a Tip without taking hands off the steering wheel with the buttons. And the buttons are not any closer or farther away than the paddles would be. I've got another car that came with factory paddles and they're fun, but I just don't see the point of putting paddles on a 993/996Tip.
But to each his or her own. If that's what you want, go for it.
Cheers.
Old 07-25-2016, 12:43 AM
justin-in-athens
justin-in-athens's Avatar
You can do it at home with the Works Bell kit in the link above. It'll cost you about $500 and you will have to order that kit out of Japan or Australia. You will also need to make or modify an existing steering wheel hub to make use of the standard 964/993 clock spring to retain use of the horn and automatic indicator cancel functions.
Details starting in post #14 here: https://rennlist.com/forums/964-foru...tiptronic.html
Old 07-25-2016, 02:58 PM
RRSLLC
Former Vendor
RRSLLC's Avatar
Thanks and yes, we offer the paddle conversion! Please PM for details.
Old 07-25-2016, 03:21 PM
AC/911's
AC/911's's Avatar
RRS, Will Do, wanna deal with someone close to me, Thanks
Old 07-25-2016, 03:31 PM
RRSLLC
Former Vendor
RRSLLC's Avatar
Looking forward to it!
Old 07-25-2016, 07:36 PM
teddysam1
teddysam1's Avatar
Look at Carnewal.com.......then email Gert in reference to tip......great guy and nice steering wheels. I believe it's a little cheaper.....Fwiw.
Old 07-26-2016, 03:23 PM
pp000830
pp000830's Avatar
Received 1,446 Likes on 1,018 Posts
Seeing that the paddles are mounted to the steering wheel they will invert when turning, I seem to recall this this was the complaint with the Tiptronic rocker switch set-up. Might just be a small issue as if the steering wheel is inverted, one is probably not running at track speeds where the paddles come into play.
Old 08-01-2016, 11:51 AM
Gert
Gert's Avatar
A Raid steering wheel mounted in a 993 sits about 1" closer to the driver so clearance is not an issue.
Old 08-01-2016, 01:43 PM
The Brewmeister
The Brewmeister's Avatar
You use the stick when the wheel is inverted. Do it all the time in my Audi TTS, which I always drive in manual mode.
Old 08-01-2016, 01:49 PM
The Brewmeister
Cheers.
If he's already used to using paddles in another vehicle the buttons could be problematic.
Old 09-01-2016, 02:41 AM
RRSLLC
Former Vendor
RRSLLC's Avatar
This Client wants to retain the 4-spoke Steering for period correctness but add shift paddles. It's been a while since we did one because it is frankly an involved task (check out my tech guy's hand!), but we decided to give it another shot. Will post finish product pictures after the wheel is re-wrapped.
Quick Reply: Paddle Shifters in a Tip Questions, Any Info?
