Timing Chain Rail Wear
Finally cleaning cam cases and getting ready for reassembly after 100k engine drop and noticed wear on rails, not surprising, but should i replace rails?
Thanks,
Thanks,
Timing chain stays in place for removal.
Wouldn't want to try this with engine in the car though - might be possible but very tight. IIRC it would not be hard to drop the mounting bolts into the case. With engine out and on a pivoting stand, you can rotate the engine so the hardware will fall away from the opening, not into it.
New rails on hand and no the "slices" in the left hand long rail were not normal, .
Steve Stomski swapped the 993 cam bolt tool i bought from Pelican for proper 964 tool (I have late 94 engine).
Based on slight wear on cam sprockets I am looking into replacing timing chains, does anyone make timing chains with master links for 3.6l engines or are those a thing of the past?
Thanks,
Thanks,
