Front blinker clear corner bulbs
Want to install clear corner front lenses and ordered what I thought were correct bulbs from autoillumination; bulb 7507. It's right sized but clearly not correct base. I can't read the numbers on the OEM bulb but attached are photos. OEM is clear. Any one have correct part number? My car is 95 if that matters
I'm pretty sure you need a 1157A bulb like this
US model 993's use 1157 dual filament bulbs for the front turn signals. Your pictures show a 1157 bulb and a 1156 single filament bulb.
ROW cars use 1156 single filament bulbs, the front turn signals are not glowing with low intensity when the lights are on as opposed to US models.
Cheers,
Tore
Cheers,
Tore
Tore, You have led bulbs? Do I need anything else or is it plug n play? I'd prefer a chrome bulbs that lights up in amber (so you don't see orange through clear).
