Bumperette Delete Inserts. Who's in?
#109
I may have made a terrible mistake and packed two sides instead of a matched pair ins somebodies delivery! Contact me(I know you will!) as soon as you get them and I will send out the other side as well as send you some cash to send me back the unwanted one!
So sorry! There were a lot of packages!
G
G
#110
G
G
Can you send me a plug for the other side?
#111
If you don't mind, I'll refund you $5 and if you could send the spare back to me I would much appreciate it.
Sorry for the snafu!
G
#113
+993 Package arrived today, safely packed in bubble wrap. The bumperettes were already off as I'm re-wiring my Turbo Scoops with proper round connectors (https://rennlist.com/forums/993-foru...o-s-ducts.html) - so I had a chance to do a test fit. Even without paint these look better than the bumperettes! The fit is pretty good, although there is a distinctly sharper angle to the plugs that leaves the outside edge a bit recessed, and the inside edge protruding a bit. Still this is a great temporary fix until i get a chance do a proper respray of the bumper and either fill the holes or get a new bumper. It took all of about five minutes to sand down the inside lip so I could slide the plug in. I left the lip on the top and outside edge intact, and the plug still fits right in. here are a few photos. Thanks GMorat! Nice to know I won't be putting bumperettes back on, ever. And if anyone needs a set of short clears, let me know!
Jim
Packaged arrived safely wrapped in bubble wrap
Tape up and sand inside lip
And the plug slide right in
This shot hi-lights how the plug is angled just a bit too steeply, leaving the outside edge recessed and the inside edge protruding slightly - still a good temporary fix
Even without paint, these look better than the bumperettes! Thanks to Gert at Carnewal for the new euro-clears!
Jim
#114
Jim
Jim
#115
Thanks everybody, it was a long process but I hope it was worth it to you all.
G
#118
Either way, I agree that this is a very good finish for the cost and level of involvement.
Excellent work to you, and especially to Gmorat.
Last edited by zechunique; 05-03-2016 at 12:38 PM. Reason: edited to clarify a bit. at least I tried anyway...
#119
I am also interested in a pair of short clears, if any other become available through this project. (Sagres74 above responded ahead of me regarding Foxman's).
Please PM me if you have a set freed up...
#120
Have you tried putting a small shim on the left side of the connection, between the car body and the plug/insert? You could use a piece of sheet metal or something? I hope this doesn't sound too hack-ish, but it might push the left face out just slightly, and you could sand down the right side (probably will anyway I assume). Just a thought.
Either way, I agree that this is a pretty good finish for the cost and level of involvement.
G
