993 Forum 1995-1998
Bumperette Delete Inserts. Who's in?
Old 03-26-2016, 02:59 PM
_snowbird_
_snowbird_'s Avatar
Does the screw hole align with an existing bolt behind the bumperette? Sorry, I haven't had mine apart before, but I assume that's why it's designed like that?
If attempting as a DIY, any prep tips or suggestions on a source or brand of paint & clear?
Old 03-26-2016, 03:47 PM
gmorat
gmorat's Avatar
Yes, the topmost bolt aligns with the hole.
I do not, I used these and was relatively happy....
https://touchupdirect.com
G
Old 03-26-2016, 04:26 PM
Foxman
Foxman's Avatar
I've also had good results with Touch Up Direct. You can save a few dollars by just buying the paint, and using your own primer and clear coat.
Old 03-26-2016, 11:49 PM
_snowbird_
_snowbird_'s Avatar
Nice kits!
G
Old 03-27-2016, 08:27 AM
gmorat
gmorat's Avatar
This if the list of people who have paid for a set of the inserts in order.
Hoggle
Foxman
Texas993
jcochran1
RJKK
E9stibi
Rockdoc
Flying_low
PG993 (need an address)
Srbean
?? (AC, trying to figure out your username)
J.O
Flyingchappy
All orders will be shipped in the sequence they were received.
Old 03-27-2016, 10:14 AM
Sandia man
Sandia man's Avatar
I sent PayPal payment last PM. Was it received?
Old 03-27-2016, 10:21 AM
gmorat
gmorat's Avatar
There was no username on the payment from 'A.C' so I'm assuming that is you. Trying to match usernames to actual names is slightly problematic at times as you have no indication as to why somebody is known as they are on the forums.
You are 11th on the list.
G
Old 03-27-2016, 10:22 AM
gmorat
gmorat's Avatar
Hoggle
Foxman
Texas993
jcochran1
RJKK
E9stibi
Rockdoc
Flying_low
Srbean
Sandia man
J.O
Flyingchappy
Old 03-27-2016, 03:39 PM
Wiseguy
Wiseguy's Avatar
payment sent!
Old 03-28-2016, 07:23 AM
gmorat
gmorat's Avatar
Hoggle
Foxman
Texas993
jcochran1
RJKK
E9stibi
Rockdoc
Flying_low
Srbean
Sandia man
J.O
Flyingchappy
Wiseguy
C4SJohn
Tougu*
Simpsoap
BOBOYDDS
Old 03-28-2016, 12:19 PM
gmorat
gmorat's Avatar
These images just came from the fabricator. He's trying different orientations to see if he can get a better surface on the main trim but as you can see, there are mixed results on the ridges. disregard the scratches, they were caused by him physically tearing off the supports rather than dissolving in a water-bath.
I think we're better off with the current orientation.
Old 03-28-2016, 01:54 PM
Mr.Woolery
Mr.Woolery's Avatar
Payment sent! Thank you
Old 03-28-2016, 05:59 PM
gmorat
gmorat's Avatar
Hoggle
Foxman
Texas993
jcochran1
RJKK
E9stibi
Rockdoc
Flying_low
Srbean
Sandia man
J.O
Flyingchappy
Wiseguy
C4SJohn
Tougu*
Simpsoap
BOBOYDDS
Mr. Woolery
Old 03-28-2016, 09:03 PM
e9stibi
e9stibi's Avatar
Just take your time to get it right before "mass production". Thanks for your effort.
Old 03-28-2016, 10:13 PM
gmorat
gmorat's Avatar
Right* for my car isn't quite as good for everybody else's. Though in fairness, these inserts fit Limeyboys car better than anybody's.
I was a little bummed out by the reorientated prints, I didn't realize it would have such a negative effect on the ridge.
Ah well! Back to the original orientation.
I think that the best way to finsih these will be to modify on the car and then sand down a bit, apply a coat of bondo on the trim surface and then refine that surface. Prime, paint, clearcoat. Drink beer. Throw Bumperettes in the trash gleefully.
G
Quick Reply: Bumperette Delete Inserts. Who's in?
