993 Forum 1995-1998
993 Twin turbo 3.8 conversion
Old 03-05-2016, 10:16 PM
White911TTOne
White911TTOne's Avatar
Default 993 Twin turbo 3.8 conversion
I'm at the final stages of completing the conversion from NA to Twin Turbo 3.8 engine. I figured I would share some pics.
Old 03-05-2016, 10:55 PM
OverBoosted28
OverBoosted28's Avatar
Single plug 3.8 ??? More info. cams, pumps!!!! :-)
Old 03-05-2016, 10:58 PM
White911TTOne
Twin plug 3.8
Old 03-06-2016, 08:44 AM
Aaron 993C2
Aaron 993C2's Avatar
Sweeeeeet. Love the shot with the cam chain and exposed turbo
Old 03-06-2016, 11:22 AM
sand_man
sand_man's Avatar
Well this is certainly exciting (to say the least)!!! I noticed a welding bead on the heads in some of the pics, what's that all about? Looks to run along, vertically, where the head meets the cylinder. Is this strengthening something?
Old 03-06-2016, 11:26 AM
Bill Verburg
Bill Verburg's Avatar
Nice!!
I don't see how you sealed the cylinder bases, The stock thin n/a o-ring will cause problems down the road.
Old 03-06-2016, 11:32 AM
sand_man
sand_man's Avatar
And those headers...DROOL!
Old 03-06-2016, 01:10 PM
Basal Skull
Basal Skull's Avatar
Those are slip in cylinders ? Bill what extra sealing for the bases to builders do?
Old 03-06-2016, 01:17 PM
Basal Skull
And are those welded na heads or twin plugged turbo, and p&c 3.8 turbo or 3.8 na or some combo/custom -what compression do you figure?
Old 03-06-2016, 02:25 PM
pilotjosh
pilotjosh's Avatar
What a project! Please share the details!
Old 03-06-2016, 03:55 PM
Mayo71
Mayo71's Avatar
Interésting proyecto
Old 03-06-2016, 08:53 PM
White911TTOne
Build Sheet 3.8l with 8.3:1 compression
1. Carrillo rods with ARP bolts
2. ARP head studs
3. 3.8 slip cylinders with 964 turbo pistons NA O-rings used to seal the cylinders .
4. Welded heads twin plugs
5. 930 scavenge turbo oil pump driven of driver camshaft
6. GT2 Evo Cams from WebCams
7. Mechanical lifters
8. 993 turbo oil feed lines
9. k24 turbos
10. Motec m48 used with OEM harness
11. Plx wideband O2 sensor
12. plx boost/vacuum sensor
13. Protomotive intercooler with intake hoses
14. 72lb injectors
15. 3.5Bar fuel check valve
16. FR5DTC plugs
17. 5 bar fuel pump
Old 03-07-2016, 08:28 AM
sand_man
sand_man's Avatar
Curious why the exhaust port header flanges are 4-hole on the passenger side and 2-hole on the driver.
Old 03-07-2016, 11:43 AM
trophy
trophy's Avatar
Makes them interchangeable with a 964 style head, manufacturer doesn't have to make a specific 993 and 964 header for the LH head.
Old 03-07-2016, 11:52 AM
trophy
trophy's Avatar
2. ARP head studs
9. k24 turbos
14. 72lb injectors
16. FR5DTC plugs
17. 5 bar fuel pump
Nice build list.....
Can I make one suggestion on the fuel injectors. I am running Injector Dynamics ID1000 in my 4.0l Build. When they were suggested to me I thought they were over kill from the 40lb injectors I had. The low pulse control these ID1000 injectors have is incredible, and there is never an issue of fuel delivery at the top end. My car idles with the injectors at around 5 to 10% duty cycle perfectly.
I classify them as cheap insurance when it comes to a build like this.
Quick Reply: 993 Twin turbo 3.8 conversion
