Oil change comedy
#31
Now THIS is oil change comedy (perfect song choice):
Chevy Impala explodes after an oil change - YouTube
Or was it just a loose fuel line fitting?
#32
Worst oil change story I've heard:
My brother in law changed the oil on my sisters car. But the gasket had galled onto the block and it didn't come out when he removed the filter. He puts a new filter on, fills her up with oil and tells his wife the job is done.
She is driving to work over a long causeway bridge (no shoulder) when she notices the car won't go so well. She gives it more gas. Car goes even slower. Then the engine stalls and the wheels lock up at around 35mph. She skids to a stop.
The new filter gasket on top of the old one didn't seal up too well. Car lost its oil and the engine seized. Car was totaled.
#33
Never forget my worst oil change story, customer version, back when I was working at the general repair/sometimes race ship. One of our customers buys himself a brand new Mazda (piston engine) sedan. Figures he'd change the oil himself. Forgets to tighten drain plug. I think we went .030 on that crank to save it--there were no crate engines at that time, and really no parts for non-rotary Mazdas. To this day I think that was the closest to new engine I've ever had apart.
Flash forward to a week ago. Change the oil on the 996 Turbo before I head down to Phoenix. Can I keep from making a mess? NOOOOOOOO. Damned (engine mounted) sump tanks let it gush out so fast it overwhelmed my oil catch setup. Spent as much time cleaning the shop floor as I did with the oil change + other checks.
#34
I've had a few oil changes where I thought to myself, "why the hell didn't I just bring it to the dealer and pay the $ so I wouldn't have to deal with the clean up?? I always stuff a big old towel around the filler tube just in case I make a mess. I also now have a big piece of old carpet ( like 5'X5') that I throw on the ground under the car incase I have a lot of oil that misses the drain pan. Changing the oil on a 993 is a pain/messy job IMO, but I still like doing it.
#35
Yikes... good reminder. My 993 is long gone, but I now remember that filler neck.
Have to do an oil change soon on a '95 C4 that is hydrolocked with oil. The car has less than 7k miles. We'll have to remove and clean the catalytic converter as part of the project. 't will be exciting to work on the car and we'll have to make sure we have a bunch of oil pans.
Thinking about this makes me think of the old Imparts ad that you could find in Pano... never forgot that ad. Oldtimers will remember.
Pretty sure that type of drain pan is hard to find in these modern times.
#36
I've spilt so much oil in my garage, I finally switched to one of these. It's a "pond liner" and holds 9 gallons.
http://www.lowes.com/pd_93171-1569-P...d=1112805&pl=1
#37
When I was in high school I worked at a Chevron Station. We had bulk oil that came out through a nozzle with a clock-like meter. I didn't notice the small graduations around the circle. Thought each 360 degrees was one quart. Put 5 gallons of oil in my first victim. Lots of smoke on startup, luckily no damage.
#38
#39
I pretty much use all open top, low profile catch containers. So now, the only worry of a spill is in attempting to transfer the used oil to gallon jugs for disposal! UGH! I think that's another topic/thread...
#40
You guys.... there is only one proper way to change oil.
#42
What a great idea! Always challenged with 6-8 QT back flow potential when doing 1 QT at a time with funnel (before start up), after back flowing once and the following clean up.
Trick would be coming up with an oil tight seal between cap & funnel throat. But worth giving a DIY try. Next Pelican order adder ...
#45
