993 battery went completely dead. Is the battery plug and play
hay guys/gals
this weekend I discover my battery was completely dead show zero volts at first when under a charger for 3 days went up to 3 volts.
I don't know when it went completely dead. I been putting it on the charge every months. But have not been starting it and have not been checking the voltage for a long time now. So don't really know when the battery gone bad.
So my questions if I replace the battery is this a plug and play thing. The 993 was left completely unlock so no problem getting in and I have the radio code.
Anyone have a problem with the 993 battery went completely dead.
If you mean, "Is the battery a standard size?", then yes it is. You can buy the correct sized battery with the terminals on the correct sides from many manufacturers. I cant tell you the exact size but you can search for it here on Rennlist, its been discussed multiple times.
Replace the battery and drive the car for a bit. The ECU will recalibrate and the car might run funny until the system has been driven for a while. Also leaving the car unlocked will kill the battery quicker than if you locked it up. More systems are put on standby when the alarm is activated.
When I mean plug and play. I was worry about the 993 since the battery is completely dead that things will not work, right. Like the the car will not start, window will not open, other electronics not working.
by the way. Car door close but unluck, alarm not on right.
thanks
But if it is like recalburating the ECU and doing my personal settings I am not worry about.
thanks
If the car stalls soon after you replace the battery, don't worry about it. It's just the computer relearning how to keep the correct idle speed. There is some adaptation the car will automatically do.
Also, you lost your readiness flags when the battery died.
If this was a "maintenance-free" battery, in all probability, it simply went dry. So-called "maintenance-free" batteries are not. Some have two covers that pry off, revealing the cells. Others have six caps that unscrew with a Philips Head or slotted screwdriver. These batteries should be checked at least once a year. If the electrolyte goes below the plates, sulfating occurs and the battery goes bad. Remember, use only distilled water to fill.
