A look at the 993 valve lifters
When I was disassembling the rockers and one these fell out I was not sure what it was. Having seen many other valve lifters on non – Porsche engines. I was surprised to see how small the 993 lifters are. After seeing them and considering the important job they do, I think they should be a standard part of 993 maintenance once the engine is over 100k miles.
When I was disassembling the rockers and one these fell out I was not sure what it was. Having seen many other valve lifters on non Porsche engines. I was surprised to see how small the 993 lifters are. After seeing them and considering the important job they do, I think they should be a standard part of 993 maintenance once the engine is over 100k miles.
I think age breaks down the o-rings before then....especially on the bottom due to exhaust heat.
I had random lowers fail at 30k (14yrs), 40k (16yrs) and an upper at 46k (19yrs).
I hate the dreaded sound of tic tic tic! I'm always fearful that's it's somethings bigger.
Seared
They are very easy to replace and at this age the original o-rings crumble like over-cooked bacon.
I have a set of 12 stowed away for when the mood strikes me.
Andreas
Andreas
Or is any care needed to limit pressure and filtering to control ingress of foreign matter?
I'm with Rick, these are important little devices
Seems they let you know when they begin to fail as they get very loud at start-up once the seal fails. They seem to last 40 60k miles.
Yup, just another "while you're in there." I did this as part of an engine refresh for the C4 last winter, and plan on doing the same for the new C2S this winter. Clutch job leads to engine drop leads to....
Seared
Andreas
That's why I laugh when people ask what a clutch replacement should cost. I figure $3500 in parts.
Comments like this are the cause of silly rumors that get started. There are tons of 993 out there with way more miles than that on original lifters
Agree. If this rumor was true, I'd be somewhere between my third and fourth set of lifters. Doesn't seem like this theory passes the sniff test.
i figure since oil in axle, through rocker, behind lifter is not free flowing after,
any micro nano whatever goes in, stays in.
just pressure blow the passages for a clear check, and people forget to do it
