Tyres for 993 GT2
Tyres for 993 GT2
Hello, I've always had track tyres on my GT2 but as I'm going at the end of the month to the Nurburgring I would like to fit road tyres as the weather is so unpredictable
What are my best options?
Standard measures are 235 / 40 ZR18 and 285 / 35 ZR18 but I can't find any good option with these!
Any help will be greatly appreciated!!
I have Bridgestone Potenza S-04 Pole Position, which in US comes in those sizes.
It's very good in wet and decent in dry. But you gotta take 8-10psi out of them for the track compared to factory recommendations. In cold temps it still works, too.
Here is what Tire Rack shows available, if you are looking for a road tire I would vote for Michelin Pilot Super Sport.
http://www.tirerack.com/tires/TireSe...r=18&zip-code=
Managed to find Michelin Pilot Sport 2 but it's a tyre that I really dislike and I would not order unless the only alternative!
Thanks a lot anyone for the inputs!
Sorry, my bad, I meant 285/35 or 295/35
I currently have Michelin Cup 2s and the rear is 295/30/18...but there is no Super Sport that size (at least here) and there is no 305 on 18s
Greetings from the 'ring!
I am running Kumho V70A Hard in 265/35/18 front and 305/30/18 rear on my RSR so i'd assume you can fit them under your GT2 flairs. VERY good tire for the Nordschleife!
So what were you on when I was behind you, near your gaff?
Are you able to drop to 225 fronts without dialing in too much oversteer? What width are the actual rims?
Mytyres is showing 225/40 and 295/35 (12 available) in SuperSport, but Mytyres don't always tell the truth on stock levels.
I was running Michelin Pilot Sport Cup 2's in 235/40/18 & 285/30/18 on the Nürburgring during the Scuderia Hanseat drivers course in the beginning of September and they worked great even when it was very wet.
Porsche are using them as a road tyre on the 991 GT 3 as are Ferrari on the 458 speciale.
/9MRSCS
/9MRSCS
