CCU fan problem
CCU fan problem
Hello All!
Lately the CCU fan has been stopping I popped the CCU out, dusted it, checked for free spin, seemed to work. A few days later, not working. This time I left the CCU a little loose, and pulled it out when the fan was not spinning.(Tip, use a piece of tissue paper placed over the fan hole to diagnose a fan issue)
When I pulled the CCU out, the fan was vibrating/pulsing in place, not spinning.
Tore or anyone, is there a replacement fan out there? What is the volt going to the fan, 12 v?
Thanks for any help!
O'Neal
O'Neal
The fan bearings wears and the motor magnets weakens. New fan needed, Porsche part # 96465914800
Cheers,
Tore
Cheers,
Tore
Nope, not yet.
As of now, the original part is the only replacement.
Cheers,
Tore
Cheers,
Tore
The same fan is used on other makes
they pop up on ebay from time to time
there are three right now for sale
search for (denso 173000)
the mercedes one is 173000-0841
make sure you check the picture and it says 12v on the fan, because on some jaguars, it is 13.5v
then you resolder the wires for the porsche socket
-0410 Porsche
-0790 Chevrolet
-0691 Audi A8 1994-98
-0860 Honda CR-V
-0741 LandRover Discovery
-0770 Jaguar XJ8 1998-03
-0632 Chrysler 300M, Intrepid, Concorde
-0841 Mercedes
FOR THE DEAL OF THE CENTURY they are at $7.95 + shipping here:
http://www.surplustuff.com/misc.html
this way you could afford a membership, as I did
-0410 Porsche
-0790 Chevrolet
-0860 Honda CR-V
-0841 Mercedes
-790 Chevrolet
-790 Chevrolet
ToreB, the last link in your signature appears to be broken... "Safari can't find the server"
http://www.porschehvac.bergvill.com
Maybe it should be this?:
http://www.bergvillfx.com/porschehvac2.html
I understand the theory and function of the ccu fan, however in practice does it really do anything as the entire concept of the ccu controller dynamically regulating cabin temps is iffy at best. I find myself just using the blower speed **** to do this. It's actual function seems to be to collect dust and log OBD Codes for our entertainment!
Yep, mine works. At least it di before the fan started its glitch. Maybe that is your problem, and you have overcome it with manual control. Put a piece of tissue paper over the intake when running, see if it sticks.
When you first crank up the car, the ccu does id the internal temp correctly. But as the air is cooled or heated, samples are not pulled in past the sensor. It continues to sample the stale air in the tube. This is compounded with the AC switch pushed in, as the light in the button will quickly heat that general area, and after a few minutes operation, the CCU thinks the cabin is warmer than it really is!
See above...sorry
