Factors to be aware of when buying low mileage 993
I have friends that have bought 30 year old airplanes that have a few hundred hours of use and were stored in unheated hangars their whole lives. Flown away with zero issues.
I don't consider my car ultra low miles but I would consider it low mileage with about 1000 mile average per year. I do all service basis on time not mileage. Even had dual distributor belt changed as I recall this year or last due to age. Same with shocks, they do not last forever so replaced with Bilstien Pss10's
Careful inspection for leaks or sepage. When I had car appraised the appraiser did same with car on lift so he could more easily inpect everything. He even had me remove thee plastic tray under car so he cold check for leaks and make sure all cosmoline was there which indicated not work done on engine or gearbox.
So I'm with you Onami the weight given an opinion with no firsthand real experience is not the most credible.
My car is not for sale
Low mile examples have potential for oil leaks. I don't know if what one would call "danger" is involved.
Is there a minimum number of miles per year average that a 993 should be driven so as to keep everything lubricated and for acids corrosion and like not to build up in the combustion chambers? By way of example could an 18 year old 993 Have potential problems mechanically if it had only been driven has been driven a total of 2000 miles in 18 year.? Are other things to be concerned with on a low mileage 993 items such as oil gearbox hydraulic fluids be changed yearly regardless of mileage driven during the past year and also should the car be driven using ethanol mix or 100% gasoline if available?
I've heard of 128 mile 993 running perfectly fine (last year), but as pointed by others, that's a very subjective statement...fine as in it starts fine, or fine as in it runs fine on the track.
You're right I will try to change title to : Factors to be aware of when buying low mileage.
