The latest on exhaust tips circa Aug 2015?
#61
I then used the old pipe to attach the new style fabspeed tip.
It worked!
So if you want to reuse your old fabspeed maxiflos and satisfied with Fister Stage III sound, i suggest the following:
Send your mufflers to Fister.
Buy a pair of the new Fabspeed tips.
Take you old fabspeed tips and cut off the attachment pipes and re use them on the new fabspeed tips.
Fabrication in the form of grinding, cutting and welding is required but the end result is beautiful apperance and sound from an old set of Fabspeed maxiflos.
If you already have the mufflers, it will cost you the bill at Fister and the cost of the new tips from fabspeed along with a day of cutting and welding.
I have the Gillet muffler and 993 C4S widebody thus i used Fabspeed widebody wide ovals.
I can only assume the Fabspeed narrow body wide oval tips will also work on a narrow body car being Bichof or Gillet.....
