993 Forum 1995-1998
Project RSR
Old 08-24-2015, 06:33 PM
  #31
cup997laurent
cup997laurent's Avatar
On my 993 cup modified to Rsr I had gt2 adjustable Bilstein but for a road use its way too hard , so cup suspension would fit better .
Old 08-25-2015, 01:54 AM
  #32
fsa
fsa's Avatar
Default Euro spec
These pictures remind what US spec cars are missing- side marker/directional signal lights. This was a foolish omission, probably to save 25 -dollars, when Porsche was struggling financially
Old 08-25-2015, 07:22 AM
  #33
RSCS
RSCS's Avatar
After the dry ice blast this is how the car looked. If you look closely at the roll cage you can see very small pieces of glue all over it.Now I have to get out the Xylene and start breaking down the glue.
Old 08-25-2015, 07:46 AM
  #34
Raven 666
Raven 666's Avatar
Some motivational images for you RSCS ...............
Old 08-25-2015, 05:43 PM
  #35
Bill Verburg
Bill Verburg's Avatar
993Cup or 993RSR for road use??
the oe Cup/RSR/GT2 Evo shocks w/ linear valving were way too harsh for road use, I have revalved Cup shocks on mine that are barely ok for that. The redo needs to include digressive valves, like Moton and MCS use. W/ a digressive revalve even the stiffest springs are street useable.
Old 08-26-2015, 08:30 AM
  #36
RSCS
RSCS's Avatar
Spray the Xylene then wipe, over and over. You can see that I am making progress.
Old 08-26-2015, 09:12 AM
  #37
Raven 666
Raven 666's Avatar
Nice work Mate looking a lot cleaner ..............
Old 08-26-2015, 09:42 AM
  #38
Holger3.2
Holger3.2's Avatar
did you try MEK?
I used 1st MEK, then Gasoline and for the finish MEK again.
Worked very well for me!
before:
and after:
Old 08-26-2015, 11:00 AM
  #39
k722070
k722070's Avatar
another glue idea, I used a heat gun and rags.
you still need the proper mask and fan for the fumes.
heat up a section of glue and smear or scoop it up with the rag, this removes all the puddles and thick stuff.
the final clean up with 3m adhesive remover was very quick and easy.
Old 08-26-2015, 12:41 PM
  #40
Spyder_Man
Spyder_Man's Avatar
As a former chemist, please, please, please use the proper type of face mask. Certain ones are designed for certain types of chemical exposures. Xylene and Methyl Ethyl Ketone (MEK) are organic solvents, so make sure you are using a mask that protects against such fumes. Take lots of fresh air breaks too. Swap out your face mask (or filter cartridges for the mask) often. Don't get the stuff on your skin. I wouldn't be surprised if both of these products are "mildly" carcinogenic (i.e. causes cancer).
Stay safe while pursuing your hobbies folks!
Old 08-26-2015, 01:59 PM
  #41
Holger3.2
Holger3.2's Avatar
Actually that can't be mentioned often enough!
Additional to Spider_Man's advice, i placed a really big fan behind me, blowing the fumes out of the other sites door.
Old 08-26-2015, 04:54 PM
  #42
Spyder_Man
Spyder_Man's Avatar
Default Project RSR
One more thought, please keep any pregnant ladies away from the shop area while you're working with those chemicals.
Old 08-26-2015, 05:36 PM
  #43
RSCS
RSCS's Avatar
Spyder_Man, I used a mask and gloves all the time and I also had the front and rear glass removed to help with ventilation.
Old 08-26-2015, 05:56 PM
  #44
Bill Verburg
That brings back memories, fuzzy ones though
Old 08-28-2015, 09:50 AM
  #45
RSCS
RSCS's Avatar
More hours. Getting cleaner.
Quick Reply: Project RSR
