Tighter Steering
Tighter Steering
Hello All!
In a quest to remove the slop in the steering, I have:
Done the tie rod pinning mod
Had a alignment by a fully vetted mechanic, used ktoe gauges
Slop still there, next is steering rack mount bushings. I have heard the rubber can deteriorate to marshmallow consistency.
Also, in looking at PET and replacement steering columns, I see a rubber guibo, or bushing. It does not look replaceable, though. Have you heard of the guibo going bad?
Thanks for any thoughts on the issue!
Not just pin the tie rod, but you may need to replace the tie-rods ends if the ends are sloppy b/c it is old.
3 things I have done to make my steering feel great: 1) good tie rods. 2) pin the tie rods. 3) strut brace.
FJG,
Yep, control arm bushings replaced with the walrod ones.
Terry,
Slop- for me, at highway speeds, I can move the steering wheel off center, left and right, a couple degrees, and it will have no steering effect. Really need to have someone move the steering wheel a little, and asses the movement under the car. The trouble is to observe, the car needs to be lifted to get under there. Now the wheels are unburdened and move easily. Need something like a pit at Jiffy Lube etc.
Steve,
I will be installing new rack bushings, this is a '95, so the old ones are 20 years. Going with the urethane, any cost effective supplier come to mind?
OD
Terry,
Steve,
OD
Basic Sponsor
Yes, replacing these with new ones will make a difference. Upgrading will also tighten up the slop you are describing. I upgraded and could really feel the difference.
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Is there a difference between the black ones on Pelican's website $4) and the blue polyeurethan on Rothsport website ($40)?
Basic Sponsor
Small changes in an alignment can profoundly alter the precision of the steering feel. Is the looseness at all speeds or does it get progressively worse with speed?
