993 Forum 1995-1998
Are my engine mounts shot ??
Old 06-26-2015, 03:58 PM
pozzello
pozzello's Avatar
Default Are my engine mounts shot ??
As I mentioned in another thread, my gearbox feels notchy and I was advised to check the engine mounts. Should there be that much sag ?
Opinions ?
Paul
Old 06-26-2015, 05:19 PM
jg291446
jg291446's Avatar
I think so. My muffler tips looked like yours before and the genre change was like if I was bumped in the back. I used Wevo black and really satisfied. I bought them from pelican because I never got an answer back when emailed and called Wevo.
Old 06-26-2015, 05:37 PM
fatmike
fatmike's Avatar
They are relatively inexpensive, relatively easy to change and they can make a big difference.
Old 06-26-2015, 05:46 PM
mpruden
mpruden's Avatar
I recommend replacing those.
Old 06-26-2015, 05:58 PM
Todynot
Todynot's Avatar
Are failed mounts more a function of vehicle usage or simply time/age?
Old 06-26-2015, 06:18 PM
F18drvr
F18drvr's Avatar
OP...those are worn out for sure. Logic dictates that unless you are driving your car very hard, they most likely fail because of time and age. If they are also original, then it becomes even less of a mystery. They are surprisingly easy to change DIY, well worth it, and I bet you will notice a difference in the shift. I have not done the "golden-rod" yet, but this is on my short list. (perhaps can also affect the feel of the shift... With a bit of research you can find some good explanations of both of these DIY's
PCARWorkshop is a great site to start your search.
Old 06-26-2015, 06:29 PM
pozzello
pozzello's Avatar
Does anyone have an 'AFTER' picture (mounted) of what they should look like ? How much space should there be between the plastic and metal ?
Old 06-26-2015, 06:40 PM
cgfen
cgfen's Avatar
thank you describing them as engine mounts, not motor mounts.
Old 06-26-2015, 07:23 PM
jg291446
jg291446's Avatar
Old 06-26-2015, 07:27 PM
jg291446
jg291446's Avatar
I just installed them and I have the feeling I'M on the other extremity... My mufflers were installed before, when the ENGINE mounts were shot.
Old 06-26-2015, 07:43 PM
Leander
Leander's Avatar
I replaced mine a couple of weeks ago.
Old 06-26-2015, 08:06 PM
FLYT993
FLYT993's Avatar
tell tale sign my mm were gone was the tic-tac-toe rubber grid on the heater blower would not align correctly with the opening in the spoiler.
so i installed these....https://rennlist.com/forums/993-foru...rl-mounts.html
Old 06-26-2015, 09:05 PM
Leander
Leander's Avatar
Mine looked like these when they came out. The passenger-side mount is on the left.
Old 06-26-2015, 09:44 PM
Garth S
Garth S's Avatar
Exhaust tip position is not a reliable indicator of engine mount health IMO, as tips have considerable adjustment when the band clamps are loosened.
However, exhaust tip movement is a good indicator: simply slide a floor jack under the engine case seam and start to lift the car. If the tips move upwards prior to the chassis ( or the gap of tip to bumper cover cutout closes), time for new mounts.
Old 06-27-2015, 12:51 AM
OverBoosted28
OverBoosted28's Avatar
^^^^^^^^ and if you suspect they're shot, open engine lid first, so you don't stress any of the engine lid when it is jacked up.
Quick Reply: Are my engine mounts shot ??
