993 Forum 1995-1998
Advice needed - oil level sender adjustment - gone bad
Old 05-20-2015, 04:18 PM
Johnny_law
Johnny_law's Avatar
Default Advice needed - oil level sender adjustment - gone bad
I am doing an oil change and planned on adjusting/calibrating my level sender to the gauge. Removing the six nuts, the two center nuts loosened and then the studs began spinning. Can't remove or retighten not sure how to proceed.
Johnny_law
Johnny_law's Avatar
Sorry can't send pictures getting parse errors
Old 05-20-2015, 05:10 PM
Quadcammer
Quadcammer's Avatar
Received 1,368 Likes on 792 Posts
hmm, I don't recall how the studs go in there.
Worst case, dremel a slot into the stud, hold it with a flat head screwdriver while you loosen and tighten the nuts.
That said, I was pretty sure the studs were solidly attached to the tank.
Old 05-20-2015, 05:13 PM
Johnny_law
Johnny_law's Avatar
The others are. I think the weld are broken on the two studs. I will do what you said to get it back together
Thanks Quad.
Old 05-20-2015, 05:33 PM
Johnny_law
Johnny_law's Avatar
Can't seem to get a good enough grip as the studs broke loose was the nuts were close to the end of the stud. They are mechanical lock nuts so they grip the stud tightly.
Was going to drive about 240 miles to give my Dad a first ride in a Porsche for his birthday. Now I'm not sure if I can of oil can leak out through the loose studs.
I'm really bumbed.
Old 05-20-2015, 05:46 PM
mpruden
mpruden's Avatar
The gasket may hold back the oil. Have you tried to just snug up the remaining 4 and see if you have any leaks? I bet 4 of the bolts will keep the seal tight enough if the metal doesn't bend.
Old 05-20-2015, 05:49 PM
NYC993
NYC993's Avatar
Exactly. Oil level should be at or below the openning.
And if a little sips through not a big deal.
Old 05-20-2015, 06:00 PM
NC TRACKRAT
NC TRACKRAT's Avatar
Have you got any JB Quik Weld? Clean up with a degreaser or alcohol around the stud bases. Use a toothpick to place a small amount of mixed JB Quik around the bases of the two studs that are spinning. Give it time to set up. Use plain nuts rather than locknuts on those two so they will draw up easier, hopefully without breaking the JB Quik bond.
Old 05-20-2015, 08:03 PM
vincer77
vincer77's Avatar
Nope. Ask me how I know.
Old 05-20-2015, 08:41 PM
nathan1
nathan1's Avatar
Johnny- I feel terrible that this issue has cropped up... Let me take that junker off your hands by offering a full refund...
Old 05-20-2015, 09:02 PM
Garth S
Garth S's Avatar
I'm really bumbed.
Wedge a flat blade screwdriver under the loosened nut and pry outwards as the nut is turned - that should anchor the broken weld: if space allows, a single wrap of fine wire will secure the stud from dissapearing .... then, spin on a standard nut ( without pushing the stud into the reservoir ) . Slot the end or clamp with vise grips, tighten, and spin on a second nut.
Old 05-20-2015, 09:11 PM
NYC993
NYC993's Avatar
How do you know?
Iirc the the end of dip stick is below the opening...but it may have been the time when I was a quart or 2 low on oil.
Old 05-21-2015, 03:20 AM
Mike J
Mike J's Avatar
The oil level is above the sender unit by a bit when the oil is about 1/2 up the stick - I know because I recently adjusted a sensor and dropped about 1/2 litre of oil when removing the sensor.
Do you need another trick? Take a 8mm nut that matches the stud, cut it in half with a hacksaw, and then use that with a set of narrow nose vice grips to grip the stud below the nut that is stuck. Due to the space made by the hacksaw blade, the vice grips can grab the stud but still not hurt the threads - then unscrew the nut. Use new nuts with no locking, and you can use the same method to hold the stud in place when tightening.
Its possible that 4 would hold it in place anyways - this is one of those really over engineered parts!
Cheers,
Mike
Old 05-21-2015, 09:05 AM
techman1
techman1's Avatar
Mike,
Great idea on splitting a nut to grip a stud....
Old 05-21-2015, 12:08 PM
Mike J
Mike J's Avatar
Thanks - I have never read about that one, it came from one of the scary parts of my brain ... :-)
Quick Reply: Advice needed - oil level sender adjustment - gone bad
