Are these Porsche Hub Caps Original?
#46
I find the metal caps no matter what i do will spin in the rear wheels when the turbo breaks the back tires loose at 5000 rpm. It always bothered me. Not sure how because when you go to move them by hand they are impossible to move and require me to remove the wheel to set them to the vale stem again.
#49
Thread resurrection
I had a 993 C4 many moons ago, 2006 if I remember correctly.
I bought a set of 993 361 032 11 TPP for some reason, it’s been so long I can’t remember why.
I just came across two of them in my drawer, brand new in packaging and one used. Made in Germany. They’re heading for eBay shortly.
#52
The red fades out and also lost from polishing. I found a toyota red touch up paint that matched perfectly and was easy enough to make look new with a steady hand and fine brush. I will try to find the paint code.
