Are these Porsche Hub Caps Original?
#31
The first plastic caps showed up as the "turbo" and "4S" caps around late 96-97. When the Boxsters started showing up the crest caps became plastic too. I don't remember plastic caps shipping on 993's until around 98. The non-color crest caps (standard) were aluminum too.
Grind back these two rivets to restore the crests and caps then use JB weld to put them back on, they are worth it.
Also I believe you will find the "triangle P" stamp on the back of the crest.
So is the part number correct 99336130300 for metal vs the 99336130307 plastic. Yet the pricing seems to be reversed at $23.64 for metal and $48.76 for plastic.
#32
Any idea what color red was used? One set of mine are worn like the ones shown. Would like to touch them up but will only do so if the color is right. there seems to be some translucency to the paint.
#33
Calvin, the OEM Cup II wheels on my very early April-'94 made '95 cab came with plastic caps (painted color crest).
I do have a spare set of non-painted metal caps identical to the ones Anthony mentiones here: http://www.ebay.com/itm/PORSCHE-whee...mtr&rmvSB=true but all 4 of them have "Made in Italy" stickers. So, are these OEM caps for D90s? Would be cool to paint those, actually.
I also have a spare set of 993.361.303.10 caps with forever-detaching colored crest (plastic cap, plastic crest). Would be great to be able to source some crests of the right size to glue back on. Are they even available separately? There's a bit of a description of assorted 993.361.303 caps here, though it's not very clear: http://dcauto.gotdns.com/illustratio...ghlight=179399
#34
Hey Nile, that's interesting. Did you spec the car with the optional colored crests? I recall a concave plastic cap that had a color laminate that came later then that year. Do you still have your window sticker, it was a relatively expensive up charge for color and the ones I remember we're like the OP's. Standard was a cast aluminum 1 piece that was black. You could also order the metal colored caps through the tequipment program.
Your metal caps are a bit before my time, maybe 89-90. I haven't seen enough of them to tell for sure. They do look it though.
The OEM caps had the same made in Germany sticker we see on our rotor hats.
OP's had this sticker on the back side;
#35
Question for you guys: I just received my CoA from Porsche, and I do not see the cabs under listed options. Per PO (and from what I can attest), car is 100% original with no modifications of aftermarket products/substitutions I can detect (still factory wheels and hence I believe these are the factory caps that came with the car).
Would the Porsche Crest caps be listed under the options list, or would these have been standard for a (late build) 98 C4S? (I have the window sticker which too like the CoA does not formally list the caps) TIA
#36
#37
Option code for caps is XD4. What does your manual and or Sticker under the frunk lid say? If XD4 is not there than more than likely the car did not come from the factory that way. Although who is to say the 1st owner didn't have them installed by the dealer prior to delivery?
I also agree CofA's can be misleading and many times incorrect. I have friend who has a CofA that is clearly wrong and states he has a CD changer which the car was clearly not supplied with since the tub needs to be modified to mount it. The certs are not there so it never had it.
#38
As you guys mentioned, I am discovering how the CoA can be 'wrong'. The MSRP listed on the CoA is...$110,060. My window sticker is $82K and change... Maybe they think my C4S is a TT Interestingly they list details such as "Bridgestone Tires"...
I ordered the detailed 'options list' report from www.pod-online.fr, it shows a myriad of things, including "Anti Theft Device for Wheels", but not formally anything about the center caps
#39
#40
#41
Take a look at your underhood sticker. The sticker codes are here: https://www.stuttcars.com/technical/option-codes/993/ Specifically, the colored caps would be 445, C89 or XD4 (I can't vouch for complete accuracy of this, but it appears to be fairly accurate).
#42
Hmmm... I would be surprised if these were dealer-installed option (as they had to replace an existing part, which is a bit unusual). But maybe someone would know for sure.
#43
Could it be that at one time the OE ones had metal attachment like the original caps on my previous 80' vintage Carrera and now the OE ones are plastic? I seem to remember the metal caps made rattling sounds when they got old. Then again on the period wheels the cap fit over the hub hole, not flush like on 993 wheels.
#44
OEM would have a different attachment scheme (plastic abs instead of metal round piece) and would have stamped Porsche part numbers. Tom's pictures above explain in in excruciating detail. Generally with Porsche, as with most German automotive manufacturers, if you can't find a part number on the back of a plastic part somewhere, it's not an OEM part. You can also generally tell from the front of the cap as it doesn't have the two small holes. The OEM caps do.
#45
I find the metal caps no matter what i do will spin in the rear wheels when the turbo breaks the back tires loose at 5000 rpm. It always bothered me. Not sure how because when you go to move them by hand they are impossible to move and require me to remove the wheel to set them to the vale stem again.
