Doors won't lock
What was interesting is it's the same ACU for the 968, 993 and......928. My used replacement ACU came out of a 968. My original ACU had a 928 part number.
Several for sale on Fleabay.
Hope that helps, and thanks again for your previous help over the phone.
Dave
Here's the answer Mike - Since it was only the Alarm Control Unit (controls the central locking system) that failed, it did not require any reprogramming. True plug & play. However if one needs the Drive Block/Immobilizer unit (different from the ACU) replaced then that would require reprogramming.
Dave
Dave
It was my pleasure and thanks for the answer.
I'm glad I found this thread, as my symptoms are virtually identical to David's. Today I removed the passenger seat and checked the fuse on the side of the ACU, but it was OK. I also sprayed contact cleaner on the connector junctions, but nothing works. So I expect the ACU needs replacing.
@David993S, did the used ACU part number end in 03? Some of the ones on eBay end in 00.
Thanks for posting your experience. Now I need to source a new or used ACU.
Good luck with your fix.
No problem. I know the part number, and found a used one very close to be for about $250 so will grab it and hope it does the trick in bringing things back to life.
