DAS ROLL BAR = DAS PAIN IN THE BUTT
I recently purchased a DAS roll bar for a fair price. It was local, so I picked it up. I did research and found that most state the tolerances suck and you have to really work hard to get it in the car.
All is true, I had to use the jack of the car to yield the rear bar into place. What a really poor design where you have to have unwanted preload in the joints.
In the end it took me 5 hours to get it into place all by myself. Now I understand why most people once they install it, never take it out.
I guess I can't complain, because if I want to junk it later for a Heigo cage I can get all my money back.
So if anyone is local in Orange County, let me know I would be willing to help ya out so you don't have to spend 5 hours like me.
I put in the bottom bar first. Then i installed the hoop afterwards. The majority of time was installing the bottom bar. The hoop was very frustrating to install because i had to use a rubber mallet to knock it into place and then install the bolts like a hindge.
The last rear bolt required me to spread the hoop to get aligned.
One has to take their time otherwise you can cross thread.
DAS is true!
I had some trouble with mine too, I think it's part of the charm of these things..haha. My problem was that I eye'd the bottom bar's position and paid most attention to the seat belt cassettes being installed correctly. I then, struggled for a while (hours) trying to slowly and systematically bolt the 4 points on the top hoop and couldn't get it to square up. Until I realized that the bottom bar was rotated a little bit. Once I corrected it, the top hoop bolted up perfectly without much effort. I'm taking mine out soon for a carpet swap, fingers crossed it will go smoother the second time around!
DAS is true! I had some trouble with mine too, I think it's part of the charm of these things..haha. My problem was that I eye'd the bottom bar's position and paid most attention to the seat belt cassettes being installed correctly. I then, struggled for a while (hours) trying to slowly and systematically bolt the 4 points on the top hoop and couldn't get it to square up. Until I realized that the bottom bar was rotated a little bit. Once I corrected it, the top hoop bolted up perfectly without much effort. I'm taking mine out soon for a carpet swap, fingers crossed it will go smoother the second time around!
--Michael
These roll bars are mallable steel. I helped a friend put a used one in his car and it was way off. We took it out and bent one of the legs little bit (with a floor jack I think) and it went right in after that.
