Spring Cleaning
Spring Cleaning
Checking the front of my C4S, I happened to look "inward below" and was happy to see that the oil cooler/radiator was spotless but the A/C condenser, seen below, was almost half covered with debris! Don't care to pull the bumper so will try a few tricks to fish this stuff out!
Received 5,388 Likes
Leaf blower to clean.
Sent from my iPhone using Rennlist
If you work carefully, you can unsnap the black plastic grille from its mounting tabs and maneuver it out of the opening. That will give you plenty of working room to clean this out.
