Bilstein HD Spring Float
FWIW, you have the extra thread version. Here's a picture of mine without the extra threads. In this photo, the spring perch is at its maximum height so you can see "all" the extra threads below the perch.
Bilstein HD without extra threads, max height.
Willus- max height. Do you mean your ride height is at it highest setting?
Is there something I can add to make the springs pre-loaded so the ride feels less harsh or do I need longer springs?
Thank u
RL Technical Advisor
Its the design of these springs and there isn't anything you can do to them. You either need different springs (stock, H&R) or an adjustable coilover kit such as the PSS-10 so you can adjust both ride quality and height to your tastes.
Yep,..thats my impression as well and why I rarely use/sell/install them.
My Targa has M033s and HDs. I've been told my ride is pretty smooth compared to a 996 C4S (apples vs oranges). I can't tell one way or another as I don't have another car with which to do a relative comparison.
The best street ride I have come up with is Bilstein HD & H&R springs. Prior Bilstein HD & OEM U.S. standard springs were harsh at low speeds. Have to conclude the OEM springs were the main contributor. H&R progressive wound springs firm yet supple with HD shocks/struts, and eliminate the hanging spring problem as static height is longer.
Do the M033s suffer from the same harshness as the M030s when paired with the HDs?
I have some more photos and a few measurements here: http://twofourthsfull.blogspot.com/2...revisited.html
which of these 3 springs can get to RS+10 with HD ?
If you need a precise RS+10mm, your best choice will be coilovers (such as PSS-10) since these fully-threaded shocks can be set wherever you want.
None of the factory springs nor H&R Sports (that fit Bilstein HD's) will do this.
M030 & M033 lowers about 12mm.
for the help.
RS+10 is not precise ...
RS+10 being used as rough guidance & lowest point .
So
M030 & M033 lowers about 12mm with Bilstein type HD .
And
H&R lowers about 38mm with Bilstein type HD .
