changing brake pad question
If before changing your brake pads, the warning light was on - should you also replace the sensors? Are they automatically damaged?
Yes. It's the sensor wearing away that causes the open-circuit.
Received 5,388 Likes
Often times the brittle heat cycled sensor breaks during a pad change, anyways.
Sent from my iPhone using Rennlist
I just did my brakes last year, when I pulled the sensors out, it was hit and miss if you damage them while taking them out, good thing I had decided to buy new sensors for replacement as 2 out of the 4 was damaged in the process, the sensors are pretty cheap anyways.
The pads have a very long life and I end up looking at the pads at least once a yer due to state inspections. For this reason I tied off the sensor wires and tie-raped them out of the way as for me they are not a real need.
