PSS10 & adjustable drop links
Nearly finished with PSS10 install, need to install drop links and set ride height.
Would I benefit from adjustable drop links or better quality drop links. Sway bar
on car measures .727 mm when measured from the center of sway bar.
My PPSS9's came with drop links that seem to work properly. I'm running Euro height..... too many challenging circumstances in my situation to go lower. I believe Rennline and Elephant offer adjustable links. Cheers
Pretty sure adjustable drop links are to eliminate preload on the sway bar.
If you pay good money for a corner balance, then you'd also want to remove any preload.
IMHO, it's overkill for street use. Just align the car and don't worry about corner balance and adjustable drop links.
If you're serious about the track, then absolutely get the real deal drop links.
