Help!!!! Identify this chassis part?
Hello all, I need help in finding a part number for a specific underside/body part/ It is a plate that goes below the shifter mechanism on 2wd drive cars. It "boxes" in the shifter bushing mount plates, and the lower rubber boot ( where the locator arm and shift rod ( goldenrod) go thru attaches.
Basically it is a flat almost rectangular plate, with an oval cut out and a lip to accept the above mentioned rubber boot.
I would much prefer to buy the factory part ( new or used) than fabricate one, although, if I can't find it, I may have no choice.
I have already looked thru the PET and I cant seem to figure it out. It is certainly a separate part, as it is evident by its construction and absence. Sorry I have no picture for reference as I am starting this with a tip, and it is not installed at the factory because of the clearance required for the tip shift assembly.
I will greatly appreciate any help you can provide. I will soon start posting the entire tip conversion process
Rich
Rich
Thank you kindly Mr Pervy, I will now hunt that up. Was it visible in the PET? If so any idea why I couldn't identify it? What page or illustration number.
Thank you again
Rich
Thank you again
Rich
