Windshield wiper removal
permanently removing the windshield wipers.. Rather than leave bare posts, does anyone know a plastic cap to cover them up for a more finished look?
I'm not going through the trouble of shaving them...
I had some caps machined out of black delrin (hard plastic) and threaded so they just screw on. I looked for something off the shelf and couldn't find anything. good luck
I was gonna suggest what is called a "**** hole" cover. It's a plumbing item that covers the unused holes in your kitchen sink. They're usually stainless steel
Similar to this
Should have mentioned... I'm just removing the arms. Motor and shafts will stay.
What will remain is an outtie.. Cap will be an innie..
Just affraid of ever having to deal with this, and not being able to have them, just in case. Otherwise, I'd be doing it also
Attachment 915905
Attachment 915905
No Garth, I thought he removed the whole assm. This was a downpour at Laguna Seca, where I needed my wipers. Actually the track needed wipers. Rivers were running across some areas. :-)
( confessional - the M3 wheel on my old E34 sits barely a finger width away from the wiper stalk, so I've done just that)
Ahhhh ha - my bad - from the pic, I'd assumed that with frantic sawing away at the wheel an errant pinkie had inadvertently tripped the wiper switch - on a dry day ...... not that that would happen to either of us
I took the wipers off of Rufus, and covered the nipples with black rubber vacuum line caps from an auto parts store. Because of the taper, the caps will eventually crack and need replacement. But they are very cheap. The result is a very clean look (to my eye).
