Driving will probably be of no problem unless you race/drive hard. Keep an eye on the oil temperature to be sure.
I am very interested in buying your old CCU. Please contact me, you have disabled/not activated your Personal Messaging here on Rennlist.
Cheers,
Tore
I Will contact you. Just waiting for the new unit. They told me 10 days but...
Thanks for your help!
This is the vacuum actuator for the rear air intake. It shall switch to upper snorkel intake if the reverse gear is selected, and heat is needed in the cabin. (heat control on CCU is set above minimum) It reduces the chance for sucking in exhaust fumes when driving backwards.
Cheers,
Tore
