Replace foglight bulbs on Euro style bumper?
This is not the factory fitted original combined fog and marker light enclosure. The pictured lamp is no fog light, it is a common side/marker light lamp used in the "Turbo S" scoops. . It uses 42mm festoon bulbs. I recommend using a LED festoon bulb in this to macth the colour your HID lights.
Cheers,
Tore
Cheers,
Tore
I guess you mean the park/marking light in the front fog light housing? They are Ba9S bulbs. Turn signal bulbs are all BA15S/1156 type on euro cars. US cars are using BAY15D/1157 in front turn signals. (double filament bulb)
You see the full bulb setup explanation in my T-LED kits, I have several versions depending on needs.
Cheers,
Tore
Cheers,
Tore
