Oil Loss After Top End Rebuild
I have been monitoring my oil levels consistently after my top end rebuild last year and noticed that I am still losing about a qt every 1500 miles. Tim from Fastlane Porsche put stronger valve guides when putting the engine back together, so I know the valve guides aren't the issue.
Any info would be much appreciated, this is my first P-car.
"Top end"? Just to confirm rings, heads and valve train? Barring no leaks, a quart at 1500 miles is not really excessive (I think) while rings are still seating. How many total miles since top end. If not new rings, then check plugs for fouling. That's a start. Also what oil you using? Good luck
Thank you responding
You did not state unequivocally that rings were a part of the top end rebuild. Rings need to be seated properly and I'm fairly certain, driving like you stole it is not an acceptable practice for seating rings.
[QUOTE=nine9six;11933378]You did not state unequivocally that rings were a part of the top end rebuild. Rings need to be seated properly and I'm fairly certain, driving like you stole it is not an acceptable practice for seating rings.[/QUOTE]
What I meant to say was. I kept the RPM above 3k and varied the RPMs when driving on the freeway.
What are your methods and measurement points for adding and topping up oil? This may be a factor in the game of apparent vs actual oil consumption/loss rates.
If there is any doubt in your mind, take a look at this
'08 thread on oil consumption measurement - if you have already determined the 'sweet spot' on the dip stick, then please ignore, for I have nothing useful to add.
Let us know what your top end included. Still think you're fine with your consumption.
Before I check the oil dip stick, I let the oil thermostat open then drive the car some more until the temp gauge gets to the 9 o clock position. Then I leave the car sitting(Running) for a few seconds to check the dip stick. If oil needs to be added, I add a half quart at a time.
I took a look under the car and noticed some oil leaking from one of the lower valve cover, not much though. Overboosted28 may be right about my consumption being normal.
