Uneven brake pad wear
I just changed my front brake pads and noticed rather uneven pad wear. The outboard side is worn more than the inboard side and the driver's side is worn more then the passenger side. Any pointers to potential root causes? The car does not pull left or right on breaking.
Much appreciated
Much appreciated
Much appreciated
Much appreciated
When it doesn't it is usually an indication of sticking or frozen pistons.
Your calipers probably need to be rebuilt,
The main preventative measure is frequent fluid changes, at least annually. The less the car is driven the more attention the fluid and piston exercise is.
Wolf, I bleed the brakes regularly, ~ every 6 months / 2k miles and the fluid usually looks healthy when it's bled.
Thank you Bill for weighing in. I was vaguely thinking about sticking pistons but wouldn't the car tend to pull to the side opposite to the one where the piston is sticking? Or wouldn't the rotor with the sticking piston be noticeably hotter than the opposite side rotor?
Thanks again
/alex
The leading edge of the pads will always have a tendency to wear faster than the trailing edge, the use of a larger piston on the trailing end and a smaller piston on the leading end is aimed at evening that out. It generally works well enough on 993 pads w/ fully functioning pistons.
Thanks again
/alex
