Tow Hook Hole Missing
I popped the tow hook cover off to see if a tow-hook-mounted license plate would fit and discovered that there is no threaded hole for the tow hook behind the cover. There is only the blank aluminum bumper support plate.
Has anybody run into this before? I didn't find anything with a search. I am guessing that the bumper was replaced some time in the past and the replacement support did not have the tow hook drilled and tapped (?).
How would be the best way to fix this - it it a DIY drill and tap, or are we talking about a body shop at this point?
-Richard
-Richard
You need to remove the front bumper to know what you have. As Cupcar said, most likely the bumper reinforcement was installed upside down.
Best picture I could find below. Bumper reinforcement is held by only two bolts.
Thanks Cupcar and Blue TTop. I never knew that plate could be installed backwards.
I got my trusty borescope and looked up under the driver's side of the reinforcement plate and there was the threaded tow hook hole!
Now I have a weekend project - remove the bumper and reverse the plate.
When you remove bumper cap, you will probably note that your temperature sensor on the left side is incorrectly installed. When you flip the bumper, note below where temp probe is supposed to mount.
In good fun, Andy
Yeah, I bought an extra Rennline towhook/GoPro mount to use in the rear at the track. My euro bumper cover has a plug on far pass side of license plate area. Removed plug and found what you did in the front. Although my bumper covers are euro, the actual bumper is are U.S. and tow receiver is in the center, behind lic. plate?????
