Convert top back to electric
Hey guys. I converted my cab top to manual several years ago after reading many posts on here. I sold my car and the guy wants it back to electric. So, I had unscrewed the 2 screws while top was up and therefore I just tried the reverse to make it back to electric. However, after it unlocks, it won't retract. I suspect the cables are not exactly in right location. Any answers for this? I suspect if I keep loosening screws and keep cycling the cables via the switch at some point it will be back in correct location???
Thanks...
Thanks...
I think you also disconnect the motor when going to manual so you probably need to reconnect it. Does the rear motor run when you hit the switch? I am on phone so cannot do a good search. But you can.
