993 Forum 1995-1998
Suspension question
Old 10-20-2014, 06:12 PM
HFDesignworks
HFDesignworks's Avatar
Default Suspension question
My 1995 with 135K on the odometer is both a daily driver and a track day toy. I am running Vonn level 2 coil overs. At my last track day I noticed the rear end feeling a bit loose. This was especially noticeable in uphill sweepers where the rear end felt like it was dancing a little bit. Also during weight transfer the tires were not gripping like they should. Any thoughts about swapping bushings or any other culprits I should be looking at? Additionally I plan to replace the wheel bearings this winter although I don't know if that has any thing to do with this issue.
Old 10-20-2014, 06:15 PM
OverBoosted28
OverBoosted28's Avatar
When was ur last alignment? Tire pressure, old bushings, alignment, tire balance...... could be any number of things. It can be an expensive elimination of mutliple culprits.
Old 10-20-2014, 06:25 PM
Knight
Knight's Avatar
In addition to all the rear bushings, I'd check your rear subframe mounts.
Old 10-20-2014, 06:28 PM
HFDesignworks
Thanks guys! Last alignment was 18 months ago. Of course I did go off track earlier this season which might not have helped.
Tire pressures are 36 hot on Nitto NT-01s.
Old 10-20-2014, 07:50 PM
Stealth 993
Stealth 993's Avatar
Also check your engine mounts, if the rear feels loose you can have a bad engine mount.
Old 10-20-2014, 08:08 PM
Bill Verburg
Bill Verburg's Avatar
The rear alignment on a stock 993 is not at all stable, the eccentrics tend to walk w/ hard use.
A loose rear can be as simple as KT out of whack, either too little or too much side to side difference, too much will tend to stabilize the rear but will scrub the tires more. Or it could be bushes, stiffer rear A-arm and KT and toe arms nail the rear end down pretty well.
36 hot is a tad higher than I use but should still be fine
Old 10-20-2014, 08:52 PM
il pirata
il pirata's Avatar
Who are you using to do the alignment?
Old 10-20-2014, 10:44 PM
race911
race911's Avatar
Where are you, relative to what the car--now modified--is capable of? I'd work with an expert to install and set up a proper, comprehensive package. Local to you, Chris Cervelli comes to mind. His stock class times in Club Racing a 993 at Laguna years ago are times I can barely touch in my stupid modified car.......
Old 10-20-2014, 11:15 PM
il pirata
il pirata's Avatar
+1 on Chris. By far the best on a 993 in Rocky mountain area.
Old 10-21-2014, 01:20 PM
HFDesignworks
I'll check Chris out. For alignments I have been going to the only place I can find near Boulder, CO that has the KT tool - 303 motorsports. Its a 40 min drive, so by Boulder standards, its not even that close.
In terms of my ability vs. the car's ability. I am on my third season of tracking this car, tracked a 1983 before that for a season, and then tracked an Audi for four seasons before that. The 993 is by far the most capable of those cars. Its still a leap ahead of my ability but I like to think I am closing in on it
Old 10-21-2014, 01:52 PM
il pirata
il pirata's Avatar
PM sent.
Notwithstanding the details sent to you via PM Chris is far more experienced in setting up Porsche suspensions. He has the Porsche motorsport KT tool. Cervelli Technical Services Wheat Ridge CO.
Old 10-21-2014, 11:00 PM
TJ993
TJ993's Avatar
My discovery a few months back - Cone shaped Rear Sway Bushings at 135,000 Miles - My thoughts are start here n make sure all the small bits are in order before you take the car in for an Allignment. Its an easy DIY. Then move onto Drop Links and Check them for wear - Usually the first to go! Alternatively you can let the Pro's help you along.
Old 10-22-2014, 06:12 PM
ricks993
ricks993's Avatar
I recently replaced my axel boots. After reinstalling everything and then driving the car the back end was dancing around to the point that it was scary driving the car. I thought something had to come loose and put the car on a lift to check out the problem. To my surprise everything was tight, nothing loose or broken. To get the axels out I had to remove the control arm that connects at the bottom of the shock and on the other end with an eccentric bolt on the carrier. I had marked their position when I had removed them and noticed that the passenger side eccentric had moved about 2 marks (on the eccentric bolt washer) when I reinstalled and tighten the bold. After adjusting the eccentric to line up with the mark I had put, I drove the car and could not believe the difference or the fact that being off 2 marks could make the car handle so poorly. I will be getting an alignment to make sure all is OK. I would check first to see if anything is loose bent or broken if all looks good it’s probably your alignment.
Quick Reply: Suspension question
