What's the white cap in the gas fuel filler door?
always wondered why they decided to make the washer fluid so accessible on the 964/993 but didn't do the same for the oil filler/dipstick. I check and top off my oil, and care about its level in general way more than my washer fluid...
Bingo! These guys sell it by the gallon, make sure you stock up: http://kalecoauto.com/index.php?main...products_id=22
Weight of water in Windshield Washer
On page 152 of the Owners Manual it states, Capacities, Windshield washer, approx. 7.4 US quarts/7 liters.
1 liter of water = 1 kilogram, there are 7 liters in the jug when full. Recall, the windshield washer fluid is also used to wash the headlights.
1 kilogram = 2.20462262 pounds
7 X 2.20462262 = 15.40 Lbs.
If you are asking is 15.40 Lbs true, it seems that it is. I have mine topped off as part of my ballast.
I was told you can use it as a mouth piece if you want to play your Porsche in an Oktoberfest band. By adding incremental amounts of washer fluid through the mouthpiece you can tune the instrument.
They tried it in 1972…did not work out.
Andy :-)
