Dynamat - 12 sq ft - on rear firewall? Yay or nay?
Hi folks,
I was wondering if anyone had any opinions on the necessity of putting dynamat on the rear firewall?
Background -
I have a 96 C2 with fister stage II exhaust and a motorsound airbox. The sound of the car is lovely. I use the car as a pleasure car. I do not commute with the car.
My gripe with the car is that the stock non HiFi stereo has atrocious sound quality. 20% of the time when driving the car, i wish to listen to music.
I spoke at length of Rod Birch about upgrading some componenents and one of the last things he suggested was to put dynamat on the rear firewall to "cut down on heat and noise". Weight concerns aside, does anyone have any thoughts on this?
My first inclination would be NOT to do this as I love the sound of the car too much. I have read in threads that this helps cut down road noise in 964s as the rear suspension is less isolated from the body. Wondering if anyone has any thought on whether this is needed for a 993. Final note - I am not an audiophile ... I will not be using subwoofers. If i could get my 993's stereo to sound like the stock stereo on my 2006 Volvo I wold be thrilled.
Background -
I did this on my 993 coupe after removing the sound pad that is in the engine bay. I completely covered the inside of the rear firewall with Dynamat, from the top of the rear seat buckets up and back to the bottom of the rear glass. I actually took decibel readings before and after (there's an app for your phone). It made virtually no difference -- a one-decibel difference to be exact. What I found really makes a big difference in the sound level, and especially the detail of the sound, is the thick mat under the rear deck (the big shelf the speakers mount to). I think for Dynamat to make a sound (as opposed to vibration) difference, one would have to cover a lot more of the rear of the car with it than just that one area.
Or do you mean to say that since the dynamat has quieted the engine noise down that you now OPEN THE WINDOW to hear the engine noise?
I went through several types of soundproofing with my previous 964 to try and quiet it down, all to little or no avail. I tried an elastomer brush on liquid called Quiet Car and it did not help. Also tried Cascade Audio Engineering sound pad over the whole rear interior area and lastly had a custom heat barrier material and Dynamat installed. None of it ever made a noticeable difference. My 993 is so much quieter than the 964 that I have never thought about trying to make it quieter, and I always listen to the stereo. I personally would not ever bother again. Tires make more of a difference in sound generated, but with the superior isolation of the 993 rear suspension I don't find it necessary.
I installed Dynamat behind the rear seats and found very little improvement in Hi Fi sound quality ... I now listen to the motor rev
I installed dynamat in the lower portion of the doors and rear firewall and reduced the noise by 2-3 decibels. Road noise has definately been reduced. Hifi system sounds the same. It was a worth while project.
Hmmmm .... I'm just talking about the rear firewall ... Maybe no more than 15 pounds.
For those that have indicated that the dynamat mat a good difference, is it-
1). Reduction in general noise cruising at 70mph in 5th or 6th gear?
Or is it
2). Reduction in engine noise running through 1st, 2nd, and 3rd gears from 2000-5000+ rpm?
I'm thinking reduction in #1 is desirable but reduction in #2 is not.
Or is it
Thanks sacman ... Yes I would be doing the same as well ... Having rod do the dynamat install potentially. Now that the dynamat is installed and has quieted down the engine, Do you mean to say now it is easier to hear the EXHAUST sound WHEN window is open?
