Dynamat - 12 sq ft - on rear firewall? Yay or nay?
No offense meant, but why would you buy this type of car if you want to silence all the amazing sounds that make it so unique?
Sorry for little details on my initial reply. My experience with engine noise might a little misleading because there were a lot changes. My car came with the non-hifi with crappy speakers front and back so all the sound that I heard before the change was from the engine and distorted sound from the speakers. I had Rod put in a brandnew system with 1 of his own sub (highly recommended), alpine amp, Kenwood deck, focal component set in the front, new wiring, dynamat done in the rear. The sound difference was night and day.
If you want better sound I would first change out the rear and door speakers, an easy driveway job or Best Buy gig,. Even basic $35 two way aftermarket speakers will be a big upgrade over stock in clarity and in volume for a given amplifier output. If you have the Porsche upgrade speaker housings attached to your doors I would remove the entire speaker system and replace it with a conventionally mounted aftermarket door speaker using stacked aftermarket speaker spacing rings (Best Buy) to extend the new speaker frames out from speaker cut-out in the door card. I would then remount the original speaker cover furniture over the new guts for a stock look.
Another option to address sound clarity is to reduce the amount of volume (power) needed from your radio to overcome engine sounds, reduced amplifier output translates into reduced distortion and increases intelligibility of the sound. In this case anything you do to cut down the volume will help. Even a small 3 db cut in engine volume reduces the power amp watt demand by half. This is where the mat comes in. By the way 3db reduction is a small change for the human ear to notice so even though it will reduces demand substantially on the audio system you may not even notice the reduction in engine sound unless you did a side by side comparison. A 6 db reduction can even be hard to hear in absolute terms even though you have reduced the demand on your radio's amp by 75%.
I followed this thread to help reduce unwanted road noise. All of the good engine noise is still there. I had enough dynamat left over to cover most of the firewall. Addressing the doors and firewall did reduce the road noise to a much more tolerable level. We have noisy concrete grooved streets in Dallas. Wide low profile tires can really make a racket.
https://rennlist.com/forums/showthre...ferrerid=72711
Andy
