Brake Job/Holiday Weekend
Kinda looking forward to the holiday. I've had rotors, pads, brake lines, etc...in stock for about a year. My brake warning light finally came on, during my fast romp down Hwy 1 thru From Carmel to San Simeon thru Big Sur last weekend. So after PCA Cars & Coffee Saturday, she goes up on the lift for some love.
Interested to hear if your shoes fit (if you plan to replace those). The ones I ordered were 997 part numbers (confirmed correct by sunset) and they don't correctly fit into the slots.
Seared
Dont know if this makes any difference, but did you back all the way out on the star adjuster?
https://rennlist.com/forums/996-foru...g-console.html
Rare, but occasionally you'd have a less-than-skilled owner who'd make it a point to drive with the parking brake still somewhat engaged. It was more of a lining crumbling event, rather than them wearing down such that they needed to be replaced.
Ed, can you take some pics of the spiders and how they install with pads, I bought all the parts to do a complete brake job and will tackle this in a couple of weeks. I've got the Bentley manual but it doesn't show how the spiders are installed. And if you could add any tips to make the job easier, that would be appreciated, I'm replacing the rotors, pads and sensors. This is my first real on hand job with my 993. TIA
Once you pull the calipers and pads, you will see exactly how the spiders install. Its not rocket surgery...
They actually press into the bore of the caliper pistons. Pistons on the front calipers are different sizes, (larger and smaller) dia. This is the reason for the different sized spiders.
As soon as you see it, you'll get it
compress pistons
remove pads
clean calipers
peel paper from spiders
place spiders in pistons
install new pads
slide and fasten calipers in place
squeeze brake pedal
voila, spiders are installed
you can sort out the rotor and sensor replacement from there
i would be surprised if the parking shoes need replacement as they are subject to very little use in motion. My experience has been that if I use the standard dealer supplied pads with the spiders it will result in a quiet bake system. With aftermarket pads, even ones made by the OE supplier, not-so-much. It is a little tricky to get the pads in with the spiders in place. i ended up putting the spiders in place in the caliper cups and pealing back the adhesive.
Once done I slid the pads into position. To get everything in and to clear the spider's adhesive face prior to having the pads fully seated in the caliper I chamfered the inside (concave edge of the friction material on the pads to increase clearance.
Hope this helps,
Andy
Hope this helps,
Andy
Pretty much the drill. I used a painter's knife to separate the spiders from the pads. You remove the backing paper from the spiders and they aren't super sticky-allows you to slide the pads in.
I think I got my use out of the pads. Funny, I'd have cringed if I ever let the pads on my '84 get down that much, when I was in my tracking days.
Went out this morning and bedded the pads in. I love the Porterfield R4S compound.
