Heat exchanger hose alternative
During oil change, we must remove the short heat exchange connector which includes appx 2" orange/brownish rubber hose. Replacement from Porsche is sold at a 6 ft section at appx $200.
I utilized a high temp silicone hose from Forge Motorsports. Installed on the car and no issues with fiting it.
The OE is appx 2.1mm thick vs. Forge silicone is 5.1mm
The hose diameter that fits properly is 70mm.
Color choices: blue and black
Appx replacement cost depending on shipping $20
I have never had to remove the heater flap/valve assembly to change the oil and filters. I work through the RR wheel well detach one side of the hose leading towards the front of the car from the valve assembly and push it out of the way. I also do not detach the other hard pipe that so many say needs to be removed.
Go figure? Thanks for the tip on the hose supply!
I paid the Porsche tax and bought the 2m length of it. If anyone needs some, let me know. Ill look up what I paid, cost will be same as I paid plus shipping.
$2.68/inch plus postage (cost was $209.30 for 2 meters) this is the tubing purchased through Suncoast Porsche but it is 73mm not 72mm. I am not sure why the difference. I'll upload a picture of it tomorrow am.
