993 Forum 1995-1998
Replaced SAI check valve but still throwing code..
Old 08-07-2014, 01:40 PM
nine9six
nine9six's Avatar
ALSO, I Use 44K - Before Oil Changes.
TJ,
Did you mean, BG 44K fuel injector cleaner?
Old 08-07-2014, 03:09 PM
TJ993
TJ993's Avatar
yes
Also, a question - in one of my prior posts re the SAI you suggested Generic 02 sensors. Can you advise the Manufacturers name and Part Number?
Also, Brandon, you may want to try switching the 02 sensors.
My 97 has Four - Twp Pre- catalytic and 2 Post or After the catalytic.
What I am saying is this:
Remove the Pre-0Cat 02 Sensor and install it on the opposite side3 - Pre-Cat
S0 remove drivers left and install that sensor in the passenger side before the Cat and then do the opposite.
Thats Passenger side Pre-Cat - remove and Install in the drivers side.
Good Oxygen Sensor or 02 sensor test.
Originally Posted by nine9six
TJ,
Old 08-21-2014, 01:47 PM
BrandonTR
BrandonTR's Avatar
TJ thanks for the advice, I live in NW Indiana. The O2 sensor tip is great, it's sort of like swapping tires until you find the one that is causing the vibration lol.
Just to follow up, I have driven my car now for several weeks without the CEL coming back. So I think my new SAI check valve and my follow up re-attaching the pigtail hose I knocked off has done the trick for now.
Driving my car with no light on is like heaven and I only have RL to thank, so thanks guys!
Old 08-22-2014, 07:00 PM
TJ993
TJ993's Avatar
VERY COOL !
Glad to Hear that D_ _ _ Light is Off !!
On the other hand ZI just Drilled My Ports out.
Nasty dirty job till u get the hang of it.
Stay with the Ethanol free Gas. Perhaps others can chime in on the Preferred Gas in Indiana?
Best we get here is the Shell V-91 Ethanol Free.
I add Lucas Injectort Cleaner with every third or fourth tank of Gas.
If u needany info on the drilling let me know!
Cheers!
Tom
Old 08-23-2014, 12:47 AM
CalvinC4S
CalvinC4S's Avatar
Hate to burst your 95 bliss, but SAI can be bypassed to the exhaust and plugged at the heads.
Quick Reply: Replaced SAI check valve but still throwing code..
