Heater Duct
Heater Duct
Hi Guys,
Wanted to take your opinion.
Porsche 993 Carrera RS Carbon Fiber Heater Duct Bypass Pipe
or
Porsche 993 Carrera Heat Duct & Fan Block -Offs
To note, i live in Kuwait where the temp exceeds 50C hence no need for heat at all! However, the PIPE does look good and clean. what do you guys think ?
Najeeb
993 '95 Iris Blue
or
Najeeb
993 '95 Iris Blue
Even without any blower motor or fan duct, your system will pull enough heat with the front fan if you ever needed it. However, removing the blower also eliminates the after run function cooling down the engine and heat exchangers after ignition off.
Is there any harm in the heat exchanger and engine not being cooled off by the blower?
I want to do the bypass pipe but my car is still a street car and I don't want to do anything that could damage my engine longterm.
