993 Forum 1995-1998
Porsche announces its own oil for air cooled cars- restarting the oil wars
Old 02-24-2015, 09:10 AM
  #31
sand_man
sand_man's Avatar
Originally Posted by Steve Weiner-Rennsport Systems
(For those with a technical bent who are curious, we found that 15w-40 oils made significantly more power on the dyno compared to heavier viscosities such as 15w-50 & 20w-50, in back-to-back testing. That said, certain environments call for the thicker stuff when outside air temps are over 100 deg F and/or an engine has a lot of miles on it where engine clearances are wider.)
As always Steve, many thanks for the expert advice and info. I've been using the V-Twin 20W-50 for years now (previously in my 930 and now in my 993). However, the colder weather this winter in NC has me wishing I had a thiner oil to fall back on. What brand of 15W-40 can you recommend?
EDIT: I should also add, that I'm looking for something "off the shelf", if possible.
Old 02-24-2015, 09:29 AM
  #32
irule
irule's Avatar
I'm using 5w-40 for years and my engine is flawless.
The temp here is 99% of time above 50 F.
Old 02-24-2015, 10:20 AM
  #33
_snowbird_
_snowbird_'s Avatar
Out of curiosity - how do you know?
Old 02-24-2015, 10:30 AM
  #34
NYC993
NYC993's Avatar
+1 also, could you share the oil analysis and driving habits?
Old 02-24-2015, 10:35 AM
  #35
sand_man
sand_man's Avatar
^^^^Yeah, I take those comments with lots of seasoning. And to remove any ambiguity, please be more specific; what brand!? If I wasn't clear, I'm on Mobil 1 V-Twin 20W-50, and looking for something thiner yet safe and compatible for these engines.
Old 02-24-2015, 10:55 AM
  #36
Ed Hughes
Ed Hughes's Avatar
The Joe Gibbs Driven DT50 (15-50) and DT40 (5-40) contain 1200ppm ZDDP.
Old 02-24-2015, 11:13 AM
  #37
Bill Verburg
Bill Verburg's Avatar
I'm ok w/ M1 15w-50 but not 0w-40
i'd think about 4t if it was available w/o jumping through hoops
The potential issue w/ 'Racing' oil is the lack of detergents and stabilizers that prolong oil change intervals.
Old 02-24-2015, 11:18 AM
  #38
rlme36
rlme36's Avatar
Bill, I know i'll regret this, but I've been leveraging the 30% off and free shipping from Pep boys as of late. I am in the NE and usually find it on the shelves, but this way I get it delivered and best deal. Granted I only do oil changes annually, due to limited driving, but it doesn't keep me from having 4-5 changes "in Stock" at all times.
rob
Old 02-24-2015, 03:56 PM
  #39
il pirata
il pirata's Avatar
Weird…checking the Mobil site and the ZDDP levels are very different for 4T.
https://mobiloil.com/~/media/amer/us...ecs-guide.ashx
Old 02-24-2015, 04:13 PM
  #40
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Originally Posted by il pirata
If you followed the post I was responding to I was referring to ZDDP levels, and the fact that dealers/Porsche were recommending Mobil 1 0-40w even though it lacked enough ZDDP…
The online justification for not using 0w40 has been a moving target since day 1 (i probably should have quoted the earlier posts too). If 0w40 lacks enough ZDDP and/or the equivalent anti-scuffing additives than ok. But what is enough ZDDP? And what are people basing that on, previous oil formulations? (can't wait to hear what Porsche Classic says at the TechTactics presentation this weekend) And throwing oil onto the fire...
Old 02-24-2015, 06:27 PM
  #41
Bill Verburg
SG oil from the late '80's typically had 1200ppm ZDDP
SF oil before that had 1500ppm
I don't recall any hoopla at the 1200ppm level w/ SG oil
Old 02-26-2015, 11:00 AM
  #42
Coolfan
Coolfan's Avatar
I live in the Netherlands and for my 993 I changed to Porsche classic oil 10W60. I noticed that the oil pressure when warm is slightly higher (as it is 60), cold start is not a problem (10 is slightly higher than 0 and I'm not using it when it is below 5 degrees)
Further more as already mentioned the pressure when warm is higher which means the flow is lower (viscosity). However the amount of heat to be dissipated has to be transmitted by less flow. From my point of view this is the reason I noticed slightly higher oil temperatures (delta T).
I may be tempted to opt for 5W 40 (motul) , 0W50 or maybe 15W50
Old 02-26-2015, 05:08 PM
  #43
Ron
Ron's Avatar
I run Motul 15-50, 300 V oil.
I like to have Porsche explain to me how there new oil is better than what I'm using.
My contact at the dealer did not know who is making this oil for Porsche
Old 02-26-2015, 05:43 PM
  #44
irule
irule's Avatar
Mobil 1 5w40 here too.
Old 02-26-2015, 08:51 PM
  #45
Pags993
Pags993's Avatar
After a bit of research the following offering may be a solution for those running 20W50 V Twin (or other brand equiv) that would like a lighter weight oil that meets our aircooled zddp needs.
Castrol Power RS Racing 4T Motorcycle Oil - Full Syn avail in 5W40, 10W40 and 10W50 all sitting at 1200 ppm zddp wise.
Almost 100% sure it is avail at Walmart in the US along with their version of V Twin 20W50 full syn.
Quick Reply: Porsche announces its own oil for air cooled cars- restarting the oil wars
