993 Forum 1995-1998
Tarett Front Drop Link Drama
Old 05-15-2014, 03:24 PM
911PERVY
911PERVY's Avatar
Default Tarett Front Drop Link Drama
Has anyone purchased these;
http://www.tarett.com/items/993-964-...lnk-detail.htm
I did and my shop says the dont fit, there is no way they will clear the drive shaft as the bend isnt sharp enough. Ira Tarett was very helpful on the phone but didnt offer any real solution, it looks like they were made for a customer who has a special sway bar fitted and not a standard 4WD set up.
If you look at the OE ones;
There is obviously a more pronounced bend or curve to it.
Old 05-15-2014, 04:04 PM
Martin S.
Martin S.'s Avatar
If they won't work for you, just send them back, Ira will accommodate you.
I have Tarrett Engineering drop links front and rear....my car is lowered to RS ride height and has a MCS coil over suspension. The same drop links worked on my PSS 9 ...they are the straight ones...I'd take a pic but it is too hot in the trailer, and I'd have to roll the car out....
Old 05-15-2014, 04:33 PM
911PERVY
911PERVY's Avatar
Im sure Ira will sort it out, Im a bit pissed at the problem due to my car being in the shop and I have paid big bucks for these, including taxes about $400 and they dont fit. Rears arent a problem, 2WD arent a problem, its fronts on 4WD that dont fit!!
Old 05-15-2014, 04:42 PM
Martin S.
Martin S.'s Avatar
"its fronts on 4WD that dont fit!!"....what about Turbo drop links? I am certain somebody makes drop links for these cars!
Old 05-15-2014, 04:48 PM
Roche993
Roche993's Avatar
I was under the impression that OEM were the only option for fronts with 4wd. Just had to replace one of mine and could not find anything except OEM that would fit.
Old 05-15-2014, 05:03 PM
911PERVY
911PERVY's Avatar
Seems so, or though Tarett do advertise it as 4WD so eve more annoying!
Old 05-15-2014, 05:37 PM
OverBoosted28
OverBoosted28's Avatar
I didn't think anyone makes an aftermarket front drop links for the C4/Turbos. The factory links are stout enough. Apparently Tarett does but there not really needed in the front.
Old 05-16-2014, 04:10 AM
911PERVY
911PERVY's Avatar
Apparently Tarett does not......
Old 05-16-2014, 12:06 PM
OverBoosted28
Hey, I was just going by their info. posted. Sorry it's not working out
Old 05-16-2014, 12:22 PM
911PERVY
911PERVY's Avatar
Ira will sort it out Im sure, we are in communication........
Old 05-16-2014, 02:30 PM
FLYT993
FLYT993's Avatar
i was considering these dl's as well, please let know how things turn out.
Old 06-03-2014, 04:31 AM
911PERVY
911PERVY's Avatar
Well Ira has refunded me with no problems at all, a real good guy to deal with. I real shame as I want these to work but as you can see from the photos there is no way they are curved enough to clear the drive-shafts. Worryingly he stills lists them on his site as for the 4WD cars................
Old 08-09-2014, 08:20 PM
C4inLA
C4inLA's Avatar
Well, glad I stumbled upon this thread... Have C4 and almost ordered the front from these guys... Guess OEM is only choice at this time..... Buggers....
Quick Reply: Tarett Front Drop Link Drama
