Brake pipe & fitting info
Hi Chaps
I'm looking to replace some fixed brake lines shortly so was hoping to get some info for the DIY, I have replace lines in the past.
Specifically the pipe that connects inboard of the rear flexi lines, which I will also be replacing as some of the fitting unions are quite corroded.
What size brake pipe do I buy 4.7mm?
What size type on fittings do I need?
Can anyone recommend a flare tool?
(1994 993)
Age
(1994 993)
Age
