993 Forum 1995-1998
Engine Undertray
Old 11-22-2013, 03:31 PM
Greg Lab
Greg Lab's Avatar
Default Engine Undertray
At the risk of bringing up a volatile subject... A couple years ago, we had a big debate on the pros and cons of the engine undertray. It was about this time of year, but there was a guy from Canada that was going to do some cylinder head temperature tests with, and without the undertray. Did that ever happen? Any new thoughts on whether to remove it or not?
Old 11-22-2013, 03:39 PM
Mike J
Mike J's Avatar
Do not think we saw any results posted - did you search?
I run my 993's without them, and with the Turbo, I think its even more important given the amount of heat those turbos can generate. However, our weather is quite mild here in Vancouver so being too cold is not an issue. I also have disposed of several other covers for people coming in for work.
I keep the transmission cover on though.
Cheers,
Mike
Old 11-22-2013, 04:10 PM
nine9six
nine9six's Avatar
In the Texas summer heat, I would think it would be a forgone conclusion to leave the engine undertay off...
Old 11-22-2013, 04:29 PM
NYC993
NYC993's Avatar
Because the heat travels up and most of the cooling is done by the oil, my common sense would tell me that taking cover off makes no difference from cooling perspective.
Since we are theorizing here...What about the lift? Wouldn't removing tray create lift and turbulence at the rear?
Old 11-22-2013, 04:40 PM
H.H.Chinn
H.H.Chinn's Avatar
I'm thinking of putting mine back on...Just so I can say the car is complete!
Old 11-22-2013, 04:41 PM
JB 911
JB 911's Avatar
Yeah, but doesn't the fan push that air 'down' past the heads? Or does it blow the other way???
Old 11-22-2013, 04:45 PM
MACH993
MACH993's Avatar
I put mine back on for the same reason and with the thought that things stay a bit cleaner. I haven't noticed any temp difference...even during the So. Calif. summer months.
Old 11-22-2013, 05:07 PM
cpdjfd107
cpdjfd107's Avatar
ask Richard Dew what he has been doing for his 300,000+ miles.
Old 11-22-2013, 05:10 PM
L741_993
L741_993's Avatar
I was wondering where they all end up... http://www.ebay.com/itm/Porsche-993-...903123&vxp=mtr (no affiliation)
If they are so great why does he have 11 of them?
Old 11-22-2013, 05:14 PM
XavierLaFlamme
XavierLaFlamme's Avatar
My tray is protecting the ceiling of my garage.
Michael
Old 11-22-2013, 05:20 PM
goofballdeluxe
goofballdeluxe's Avatar
I don't know if running without and engine tray has any advantages, but running without an engine tray does come with some risks, FYI.
Several people have had damage to their heater flapper boxes, which, if your car is lowered and without an engine tray, can catch on driveways and such and result in damage to the boxes and other exposed engine parts.
Old 11-22-2013, 05:35 PM
96PCarrera993mg
96PCarrera993mg's Avatar
Porsche designed these cars with the trays so why remove them? If a 993 is experiencing high temps then there's an air or oil cooling issue. Mine has the tray as intended by Porsche and runs perfectly.
Old 11-22-2013, 06:18 PM
nile13
nile13's Avatar
Did Porsche also design your Eibach springs, oval tips, clear corners, T-lights or aluminum pedals?
Old 11-22-2013, 06:22 PM
TMc993
TMc993's Avatar
And here we go...
Old 11-22-2013, 07:22 PM
David A
David A's Avatar
I'm guessing that noise regulation was 1 of the reasons the 964/993 had one from the factory. Aircooled engines are noisy and the EU got tuff with that in the 90s.
Quick Reply: Engine Undertray
