993 Forum 1995-1998
CR210 Gets Bluetooth/iPhone Integration
Old 10-23-2013, 10:26 AM
jlivingood
jlivingood's Avatar
Exclamation CR210 Gets Bluetooth/iPhone Integration
I have a CR-210 (not CDR) in my 96 C2, and wanted to move away from an old FM dongle that plugged into the cigarette adapter. After much research in the threads here I selected the iSimple TranzitBLU, model # iSFM22 (see http://www.discountcarstereo.com/iSFM22.html and http://www.isimplesolutions.com/product.aspx?zpid=543). I also needed a male ISO to female DIN adapter (see http://www.discountcarstereo.com/BAA11SN.html).
The iSFM22 seems optimized to Apple devices - there is an Android one called the iSFM21 (http://www.isimplesolutions.com/product.aspx?zpid=542) but as near as I can tell they are functionally equivalent and just come with different app download instructions.
I successfully installed it last night. Here's how it works:
1. Remove CR-210 from dashboard.
2. Identify the switched power and ground lines coming into the radio harness.
3. Splice into the switched power (not continuous power, be sure to test with a multimeter if you are unsure, otherwise you will have a battery draw and eventually dead battery) and ground, connecting the power and ground lines of the iSFM22. It comes with an optional power switch that I did not use. Take appropriate electrical precautions by using good/tight connectors, wrapping wires with electrical tape, etc.
4. Connect the FM radio harness to the iSFM22's radio input line.
5. Connect the iSFM22's radio output line to the back of the CR-210. I used the male ISO to female DIN adapter to do this.
6. On the side of the iSFM22 there is a switch where you select the FM frequency to broadcast on. You can select 3 different pre-programmed frequencies in case one overlaps with a pre-set station you want to listen to, or the 4th option is app-defined.
7. Download the Tranzit BLU app from the iTunes store, see https://itunes.apple.com/us/app/isim...522169936?mt=8 and install it on your iPhone.
8. Power on the car's ignition (last key turn or engine on).
9. Turn on bluetooth on your iPhone, discover, and connect to the iSFM22. The iSFM22 takes about 5 seconds to start up once it has power.
10. Open the Tranzit BLU app and select an FM frequency.
11. Tune the CR-210 to the selected frequency.
12. Select a song on your iPhone (or Pandora or whatever) and click play.
13. Listen to wonderful-sounding, wire-free music from your iPhone on your comparatively ancient CR-210.
14. Now that you have tested this, carefully slide the radio back into the dash and go have a beer.
Your FM reception is unaffected and not diminished in any way. Audio quality from the iPhone is excellent. AND there are no wires -- your phone need only be within typical bluetooth range. All this for under $150.
YMMV but so far I like it and now I'm all set for a road trip this weekend!
Old 10-23-2013, 11:45 AM
ilko
Agent Orange
ilko's Avatar
Great write-up! I have a similar set up - bought this after a review from BobbyT: http://www.discountcarstereo.com/BLU-BKR.html
It hooks up to the antenna but also to the CD Changer port and is plug-n-play on a CR/CDR-220 (not 210!) and Traffic Pro. You use the Aux port or the FM antenna. As good as it sounds through the FM it's even better via the Aux port. I have a stock audio set up with the Hi Fi option and am very happy with the sound.
Old 10-23-2013, 12:47 PM
jlivingood
jlivingood's Avatar
I saw one of your posts and looked at that one, but was bummed that it didn't work with the CR-210. Basically they are the same units but with different wiring and it's nice to go bluetooth.
Old 12-30-2013, 11:41 AM
charlieo
2nd Gear
charlieo's Avatar
Default Looking for DIN to ISO Antenna adapters.
Great write-up. I too have been looking for a way to add bluetooth to my vintage Becker CDR-210. To my amazement, I found the ISFM2351 that will not only stream music, but allow me to make and recieve calls via bluetooth, hands free. Less than $100! Sounded great until I pulled out my CDR-210 and tried to connect the antenna. No doing. The ISFM2351 is setup for the ISO type, while the CDR-210 uses DIN. I assume you had the same problem. Where did you find the adapter(s)? You mentioned one in your writeup, but don't you need two? One male to female and a female to male (one for each connection)?
Thanks again for you help. I'm looking forward to having this great feature.
Old 12-30-2013, 12:40 PM
ilko
Agent Orange
ilko's Avatar
I think you need something like this: http://www.aliexpress.com/store/prod...975075810.html
Old 12-30-2013, 06:58 PM
jlivingood
jlivingood's Avatar
That is exactly what I needed. I bought this one: http://www.discountcarstereo.com/BAA11SN.html
I also didn't figure it out until then head unit was out! ;-)
Old 12-30-2013, 11:00 PM
Ed Burdell
Ed Burdell's Avatar
This is a way cheaper option than upgrading the head unit! Thanks for the tip. This will be my next project.
Old 12-31-2013, 01:00 PM
BobbyT
BobbyT's Avatar
I installed the "BLU-BKR Bluetooth Audio Streaming Kit for select Becker Radios" in September. It gives great sound, but now the "BLU-BKR235 Hands-Free calling and Music Streaming Kit for select Becker Radios" has become available, so I'm upgrading to that. If anyone wants just the streaming music function, they can have the BLU-BKR kit for $40, shipping included. Full details on that kit here:
Old 12-31-2013, 01:17 PM
993anorak
993anorak's Avatar
this what I got plug in the cd charger of mine cdr 210 on my 993S
it works blutooth with the iphone
Old 01-05-2014, 02:08 PM
KMASS993
KMASS993's Avatar
Here's another option for you guys stuck with a cassette deck but want to stay original
http://www.gizmodo.com/easily-update...ium=socialflow
Old 01-05-2014, 11:28 PM
fastcarsnick
fastcarsnick's Avatar
Originally Posted by Gillesdesvallois
this what I got plug in the cd charger of mine cdr 210 on my 993S it works blutooth with the iphone
where did you get your Yatour device from? Thanks
Old 01-06-2014, 06:53 AM
M. Schneider
M. Schneider's Avatar
The Yatour audio mouse trap is sold on ebay.de often that I've seen. Often a USA ship address is not an issue.
Old 01-06-2014, 07:54 AM
quietcoolone
8th Gear
quietcoolone's Avatar
Hi,
As far as i can tell the ISFM2351 connection is similar to what jlivingood did with the isfm22. You need an FM modulator antenna kit like this or similar
Once you have the antenna adapters you should be able to make that connection to the radios ISO antenna terminals.
While your at it, buy the pah-1784 power harness for power and ground connection without cutting or splicing the factory wires.
Old 01-06-2014, 09:32 AM
993anorak
993anorak's Avatar
Wink
Here : http://www.hightech-privee.com/inter...b-porsche-mp3/
regards,
Old 01-06-2014, 10:36 AM
il pirata
il pirata's Avatar
Their site says this does not work for the CR-210. Scroll down to the bottom for two options.
Quick Reply: CR210 Gets Bluetooth/iPhone Integration
