Before I look tomorrow 220ma current drain source??
Looking for a 220 ma current drain on my 95 cab. Wondering if the amount rings a bell with anyone.. All I have done is pull fuses from underhood relay/fuse box, as well as climate control module (another issue to figure out) and no change in current draw... Draw starts around 180ma and builds to 220 after a bit. This drain is still steady after 30 minutes...
Thoughts?
Thank You
Curt
Thoughts?
Thank You
Curt
I would guess a lit lamp somewhere (door/bonnet/engine lid switch fault) or a failed transistor in the CCU. YOu could listen if the CCU fan does stop at ignition off. If it doesn't you have a failed transistor.
Cheers,
Tore
Cheers,
Tore
