Odd lights issue...where to start looking?
I run with the fog lights on generally at night. If I turn the brights on, then back off, the fogs go off with the brights, but do not come back on when I turn off the brights. If I push in the switch and pull it back out, they come back on...until the brights.
Any idea which relay or what I should start doing to track this down?
Agent Orange
Relay going bad? Switch it with another relay and see if that cures it. On my C4S I had it jumpered where the fogs stayed on with the high beams. To do that you need to remove relay 34 and jump pins 3 and 5.
That is the way it is wired by the factory!
Agent Orange
If the fog lights are on with the main lights, they turn off when you switch the high beams on. As soon as you switch the high beams off the fog lights turn on again. That's SOP for ALL cars, and our Porsches are no different.
JPS, sorry for the delay, I was on the road for a few days.
Checked mine, the fogs (driving lights) do come back on when main lights are switched from high beams back to low beams. So my thought is that the relay could just be getting stuck? I'd see which relay feeds the driving lights and whack it a few times before trying the sequence again.
