GimmiYour Best Shot
GimmiYour Best Shot
Changed my oil and both filters. Book says capacity is 12 quarts. I was only able to get 10 quarts in. I let it drain for a long time.The oil is so clear It is about impossible to read on the stick but appears just under one half of the distance from lower to upper marks which is about a little more than one third of a quart. I know it wont hurt to leave it where it is but I like to be full. Would you add one third to one half quart? Thanks.
12 quarts, IF you could pull the engine out and shake every drop of oil out of it, and repeat that with every oil line, including the ones running up to the front oil cooler. 10-11q is about right.
993s like to be at 1/2 full or less. They have a tendency to puke out, burn off, or otherwise dispose of the oil above 1/2 dipstick, then will stabilize and be fine. With fresh oil, the dipstick is very hard to read. Use a paper towel to lay the dipstick on and squeeze the towel around the dipstick... The oil deposit on the paper towel will show you where the line actually is.
Thanks to both of you guys. The lay it on paper is an excellent idea because I found it hard to feel or see the oil on the dipstick. Makes me feel a lot better. Just so you know, I got my Fister IIIs and wow. Sounds GREAT!!
You're over thinking this.
It takes what it takes to get it within the upper half of the dipstick.
My last three oil changes: 10.7 l, 10.5 l, 11.5 l. At 11.5 l, my oil level gauge is at 100% or full with the dipstick at "max".
Get to know your dipstick vs oil level gauge indications.
I'm unclear (unlike your oil apparently) as to whether you ran the car long enough to get the oil heated up for your final fill check...?
I know the temperature makes a difference on the volume of the oil in there. Especially when your taking about a large quantity.
I had just come back from a lenfthy hard high speed run. I let the car idle for about 1 minute and checked iy. I know it was definitely warmed up correctly. Plus someome else here said their last changes ranged from 10.5 to over 11 quarts. I could only get it to barely take 10 quarts and I let it drain for almost an hour and changed both filters. any other suggestions are appreciated.
PS. Good job on changing oil and filters. But, man...
I don't know and it really isn't important. Pretty well everybody who owns one of these is **** about the oil they use (yet they will eat junk food ) and if a bit more or less of old oil mixes in with the new, nothing to sweat about.
You did drain the oil in the engine block?
